Question about Refrigerators
AEG Santo N81840i
My holiday apartment integrated fridge freezer is not working correctly. The freezer is fine the fan is working no problem but the fridge section is not working at all. Light is working but no cold.
kweaver1
  • 3 Answers
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Posted on Jan 20, 2008
KikkaMikko
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
Posted on Aug 11, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
deby69
  • 16 Answers
SOURCE: whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Posted on Jan 05, 2009
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
Aeg santo fridge keeps freezing
Fixya will not let me post links today, or their "capcha" thing does not seem to be working properly, so I will have to try this another way.
I've done some research on your issue and it seems that should only happen if the temperature sensor goes bad, or the evaporator sensor. Each of the two parts cost less than 30 pounds each, so may be less expensive than tossing out the whole thing.
Try browsing to shop (dot) aeg (dot) co (dot) uk
Then in the search at the top right, type in "santo" and look for the two sensors and decide if it would be worth a try.
Oct 14, 2013 | Refrigerators
Fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 11, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Mar 16, 2009 | Refrigerators
AEG Santo
here is a link where you can download an english version http://www.nodevice.com/user_manual/aeg/refrigeration_1192865302/santo_3442_kg_glassline_621672048.html
you will need adobe reader to be able to read it, you can also download it for free. if this helped you then please leave feed back,cheers.
Feb 24, 2008 | AEG Santo 3888 KG8 Bottom Freezer...
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
