Amcor Portable air conditioning unit AMC9000M
Unit not cooling properly, what can I do to improve the unit?
  • 5 Answers
SOURCE: blue ice air conditioning unit (portable) not heating erro message E8
Every co. has their own logic control and error codes , however in my knowledge it may be of :
1. motor connection
2. Defrost sensor error-chk condensor/ evap. coil
provide some more clue to explore option of trip.
Posted on Feb 01, 2008
SOURCE: cooling
Is the fan blowing. If so your compressor is probably the source. If the fan isn't blowing you might have a bad fan motor
Posted on Jun 20, 2008
alex_salve
  • 78 Answers
SOURCE: My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
Posted on May 17, 2009
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
SOURCE: Need replacement hose
online http://www.amcorgroupusa.com/mm5/merchant.mvc?Screen=PROD&Store_Code=AMCOR&Product_Code=1105-032AG1&Category_Code=ALSERIES_PARTS
Posted on Jun 26, 2009
When set to heat it blows out cool air.
Chances are your portable unit is a reverse cycle unit...If so, the leaving air temp in heating mode is not usually much warmer than room temp with 85 degrees F just about the maximum under PERFECT design conditions. A small portable in a large cold room may only be discharging 75 degree air, which is going to feel cold.
If your unit is NOT a reverse cycle unit, the heating source (probably electric resistance) is either not coming on at all or a portion of it is not coming on due to a defective element, burnt wire or a control issue.
Jan 08, 2015 | Amcor AL10000EH Portable Air Conditioner
I have a portable roam air condition i dont know where to add the water
You don't account unit takes out humanity in th he air to cool house or rooms you need to drain the water to outside
Apr 12, 2014 | Amcor PLM-14000E Portable Air Conditioner
I have an AMCOR ALTL1200E, fan works, cold air comes out when the compressor turns on BUT after 5 minutes compresor turns OFF, then after 5 minutes again it turns on, what is wrong, thanks
Sounds like the unit is cycling off on a high head pressure (condenser coil too hot). When the condenser cools, the automatic switch resets. The unit cuts off again when the condenser heats up again. Clean the condenser coil, and clear out any debris (bird's nest, lint etc.)
Aug 30, 2013 | Amcor ALTL-12000E Portable Air Conditioner
I just want to know what the tube in the back of the portable unit is for?
That is where the hot exhaust comes out... it needs to be vented through a window for proper cooling...
heatman101
Jul 16, 2011 | Amcor Heating & Cooling
The unit does not blow cold air any more. Inside is sometimes hotter than outside. will be 85 inside but 80 outside. Have thoroughly cleaned filters, but no change. "comp" light is on
Hi, The compressor has gone bad and it will cost more to replace it then the unit is worth... buy another unit and buy anything BUT an Amcor unit... they are junk!!
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Amcor AF9000E Portable Air Conditioner
The cooling is not coming.I also want to know how to set it
Hi, I did some checking on this unit for you. To give you some direction to follow to what you are asking, call toll free Quality Matters Amcor.
866-725-9980
Not toll free 503-946-5869
Sincerely, Shastalaker7
A/C, & Heating Contractor
Feb 24, 2011 | Amcor PLM-14000E Portable Air Conditioner
No power to portable air condition
If the filters are clogh with dirt , the unit breaker will shut it off ,it's avery common problem , but if after the filters were cleaned it keeps shutting off , could be a bad fan motor or the compressor itself could be grounded.
Oct 25, 2009 | Amcor Heating & Cooling
Heating & Cooling Logo
11 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
