Question about Boating
Yamaha 200 hpdi starter replacement - Boating
3 Suggested Answers
subikid90
  • 180 Answers
SOURCE: beeping sound when starter is turning over for the
Have u replaced the spark plugs? Is this the beeping noise you hear when you first turn your key over the same as past times you have started the motor? It just keeps going though right? I would make sure you have the right level of fluids and make sure your fuel pump works, fuel filter isn't clogged and plugs and wires are in good shape.
If that is all good then you might have a bad coil pack. Test it and make sure you are getting correct voltages, if not then replace it.
Also did you winterize your motor after the last time you used it? If not you could of cause some internal damage to the motor.
Good Luck,
Subikid90
Posted on Mar 04, 2010
  • 677 Answers
SOURCE: yamaha hpdi 225 2 stroke throttle problems will
Your gear selector cable may only require a simple adjustment.They can and do stretch.Hope this helps
Posted on Aug 22, 2010
My mechanic can not get the foot off my 200 HPDI v max??? Any updated info that could help me?
thats an outboard motor
by the picture of all the Yamaha lower foots
comes away from the bottom with pump shaft
like all other outboards
foot and holding bolts or shaft to motor
probably corroded
plenty of lower foots for sale (wonder why )
can the mechanic take the center covers off
or strip the whole unit down
Sep 09, 2016 | Boating
Where is the oil filter for 2 stroke oil on 200 hp hpdi
Hi, Ron for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha HPDI Oil Filter The Hull Truth Boating and Fishing Forum
http://www.tidalfish.com/forums/showthread.php/250692-HPDI-owners-Cleaning-your-VST-filter
http://www.yamaha-motor.com/assets/service/manuals/1/lit-18626-07-03_1417.pdf
Yamaha Outboard Routine Maintenance Tips by Mark Marine
Jun 23, 2016 | Motorcycles
2003 Yamaha outboard HPDI will start but will not
Many possibilities. Mine had been sitting. Old fuel in HP fuel pump reservoir was clogging HP pump. I was able to disassemble, soak and clear pump and get running. New pumps, big money. My boat, twin 150 HP HPDI
Sep 23, 2014 | Boating
Any thoughts on what the issue is? Mechanic is stumped.
I think your problem is TIMING. If you check your timing I believe you will find and correct this problem. GOOD LUCK FRIEND.
Sep 21, 2014 | Motorcycles
2010 yamaha 200 hpdi
Have you replaced all three filters under the cowling?
1. Primary Filter (1st one in the Plastic Bowl)
Reference # 12 in "Prim Fuel" Image
2. Screen on the bottom of the Fuel pump-Inside the VST
Reference # 27 in "VST" image
3. Filter between the VST and the HPDI Pump
Reference # 19 in "VST" Image
Number 2 and 3 get overlooked often, and they are pricy, but they do need to be changed.
If that has been done, the problem most likely is in the fuel pumps
Reference # 24 in the "Prim Fuel" image.
The can be tested by removing them from the powerhead, DO NOT remove the fuel lines, just unbolt them from their mounting leaving the fuel lines attached. Then squeeze the primer bulb until firm. If fuel leaks from the center hole on the fuel pump, Replace them both.
e87e836d-4c03-41b2-984e-2496eb73ed3c.jpg 7cff4158-0f6c-4620-803c-7841ea37bc6a.jpg
Jul 07, 2014 | Boating
Yamaha 2005 150 HPDI wiring diagram
Looking for wiring diagrams for digital tachometer with trim indicators and warning signals. Mine had the plastic trip arm break. No trim reading on Tach face. Replaced trip arm forsensor arm and now have no reading on the tach at all except extremely light tach Number. All other electrical components work OK.
Jan 24, 2012 | Yamaha Motorcycles
Yamaha 200HP, HPDI lifts out of the water when shifting
sounds like something got put together backward . most motors will lift when put in reverse if not locked down . this is to prevent getting swamped by the rush of water going backward .
Mar 13, 2010 | Boating
Beeping sound when starter is turning over for the
Good Luck,
Subikid90
Mar 04, 2010 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
