Question about Samsung Galaxy Tab 7.7 P6810 16GB Wi-Fi Only Light Silver Android v3.2 tablet
Tw launcher error - Samsung Galaxy Tab 7.7 P6810 16GB Wi-Fi Only Light Silver Android v3.2 tablet
I have an error message that the launcher has stopped on my truly tablet. How do I find this?
The launcher is what allows your device to boot, somewhat like the bootloader on a PC. You can attempt to download a launcher from predators and install it, but that would be useless if you cannot use the device, my experience with problems like yours is to do a factory reset, be sure to backup your device if you have things you want to save. With the unit off hold the volume up and power button until you get a screen with options to reset the unit. I use miracle advanced Android tool for most things like backup and restore or removing apps, but the pastor has apps like titanium backup & restore , miracle advanced works through your PC which makes it a better choice, anyway ...good luck
Oct 02, 2017 | Tablets & eReaders
Everytime I swipe my 9" Polaroid tablet It tells me "Unfortunately, c?mara has stopped working" How do I stop this and how do I get the c?mara to work on it?
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 25 posts - ‎20 authors
Ilze C likes this. ... My husband has faster reflexes than me & managed to hit the app... This seems to happen to my HD7 every time I download an app but by .... open and a message pop up says unfortunately launcher3 has stop. i can't ... or Korean and then help me to solve the launcher stop working error ... How to Fix: Unfortunately, the process android.process ...
Jan 14, 2013
Unfortunately, the process com.google.process.gapps has ...
Dec 26, 2012
More results from forums.androidcentral.com
Missing: polaroid ‎mara
Fix for "android.process.acore" error on my tablet - YouTube
Jan 01, 2016 | Polaroid Tablets & eReaders
Why has launcher stopped working?
launcher stopped working Tablets & eReaders Questions ...
www.fixya.com > Forum > Tags > launcher stopped working
Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
Jan 26, 2014 - 22 posts - ‎17 authors
... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
[Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
forum.xda-developers.com/showthread.php?t=2069137
Dec 27, 2012 - 9 posts - ‎2 authors
Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
Error 'Launcher Has Stopped Working' ' Android Tablet Forum
Dec 12, 2015 | Tablets & eReaders
Launcher is missing
Launcher is Missing is it a luncher app you downloaded from the playstore or is it the default launcher of your phone because if its just an app that you downloaded from the playstore its missing because a factory reset will erase all your data and apps
If its the dufault launcher is your phone rooted?
Did you perhaps uninstall the default launcher using a root tool like link to SD?
If you have uninstalled your default launcher then you would have to flash a stock rom from your phone's manufacturer or download a custom rom from the internet
Sep 03, 2015 | Nextbook Premium 8 Se Android
My nook hd says "unfortunately, Home has stopped
You can use alternates to the Home app that defaults on Nooks.
The Home app and the alternatives are all what are called Launchers. You can make your Nook look and feel just like any other tablet you have ever seen. I\'ve personally been using one for years called ADW.Launcher on both my Nooks and just love it. The Nooks default default Home launcher is just a bloody pain to setup.
You can still use both launchers side by side. After running ADW.Launcher for a while you will just ask how you ever got around without it and never want to see Home again.
Jul 07, 2014 | Nook HD+
TABLET / LAUNCHER ERROR ANDROID 4.2.1
My tablet recently did the same thing. I tried everything but I eventually had to do a factory reset. Good Luck
Mar 17, 2014 | ASUS Transformers Pad Infinity TF700TWIFI...
Received message: Unfortunatly launcher has stopped
You could try the free GO Launcher HD for Android at the Google Play store, (just Google "Asus tablet launcher"), but I find that if I restart the tablet when it says "launcher has stopped" or even just switch to another screen it carries on anyway, so it's hardly worthwhile installing another launcher for an occasional annoyance (so far anyway, fingers crossed).
Dec 18, 2013 | ASUS Tablets & eReaders
Problem!!! I need help!!
That is the home screen. Have you installed a different launcher or home screen. If so remove that. If you havent do a factory reset. Unless your device is rooted, You wouldnt have access to fix that error
May 12, 2013 | Google Android Sowill oioi s7 7 inch...
A13 tablet launcher not working due to density
I just did something exactly like this on my phone. Here's what I did for solving it.
NOTE: you will need access to a PC with internet connection and your problem Device must have access to the internet. You also need access to the PLAY store on both the PC and the problem device. From what I understand from reading your explanation this should not be a problem.
1 - Start your Device as normal and when you get the force close message go to the Report option.2 - Once on the report screen (accept the terms and conditions if they appear) you should be able to pull down the notifications bar.3. On the PC go to the play store (you must log in with the same account as the one in your problem device)4. Search for a different Launcher and install it through the play store on your PC. (I used Zeam Launcher for resolving my issue but I did this on a phone so it might not be available for a tablet. You can search for Launcher and find one that way)
5. The new launcher should automatically start downloading and installing on your problem device. You should be able to see this happening on the notification bar.
6. Once finished, just go back to the main screen. You should get the option of what launcher to use. Select the newly installed launcher. (do no use the default option).
7. Once in the new launcher, go to the density changer application and change it back to the original density.
8. Reboot your tablet and it should now work correctly.
NOTE #2: I did this on a phone. I've never owned a tablet so I'm not 100% sure this will work for you.
Hope this helps solve your problem.
Jan 01, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
My daughter's new Childpad is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to reconnect to wireless router but no joy. What can I do?
Look. It happened to me and drove me crazy. I was about to brick my new mobile phone. In my case it was the "Moon call log" icon on the home screen. Believe it or not when I remove the icon the error message no more appears when I restart the mobile phone. Then again when I place it (the icon on home screen) the annoying error message "Unfortunately, Launcher has stopped" will comeback again. In your case it could be any icon or widget.
I solved the problem by uninstalling the application and installing it back from Play Store unlike what I did before by installing it from the .apk file.
Regards,
Oct 28, 2012 | Archos 4GB Child Pad 7" Android 4.0 Tablet...
Samsung Galaxy Tab 7.7 P6810 16GB Wi-Fi Only Light Silver Android v3.2 tablet Logo
19 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
