Question about Sewing Machines
Empisal overlocker tension
I have a brand new Empisal Overlocker SD40 and have spent uncountable hours trying to set the tension correct. I have had 4 people who are experts try to do the same. Nobody can get the tension correct. Do you think this could be a factory fault or what?
2 Suggested Answers
SOURCE: I dont know how to set the correct tension on my Empisal mercury model 404 overlocker
try checking with these sites and call or email them and ask
them if they know where to get a manual
sewvacdoctor.com
a1sewingmachines.com
Posted on Feb 23, 2013
New Empisal 1300 overlocker. I cannot set tension.Whether it is set on 1 or 9 it stays the same,it makes loose loops. I have tried all the other setting which is fine.
Remove ALL the threads from the machine.
ALWAYS RAISE the presser foot and rethread each thread in the order specified.
Sep 10, 2017 | Sewing Machines
Hi i have a empisal 550d overlocker . I have difficulty with cotton breaking after sewing for a few seconds. Can you help please ?
Could be the tension is set too high on that particular thread tensioner.
If it is not the tension, then this is the first thing to try (I know, it's painful but 99% of the time takes care of my issue): Remove all the threads from the machine, ALWAYS RAISE the presser foot and then rethread from the beginning. Verify that you are threading each in the "proper" order and that the threadpath for each is correct.
If it is a needle thread, replace with a brand new needle. Try a different brand of thread or spool on that particular threadpath. AVOID old or bargain bin thread. Check to make sure that particular thread is not hanging up on a burr, a sharp spot, or looped in the thread tree, etc. that catches the thread and holds it from advancing through the path.
Serger needle thread breaking sewing discussion topic PatternReview com
Lower Looper Threader Keeps Breaking Thread sewing discussion topic...
Jun 09, 2017 | Sewing Machines
Tension settings on empisal overlocker 754d, pulse ?
The standard tension for a 3 or 4 thread overlock is to set each tension dial at the midway point and then tweak it from there. It helps to use different colors of thread so you can distinguish what each thread is doing.
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
Make It Handmade Perfecting Serger Overlocker Tension
Mar 13, 2017 | Sewing Machines
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
Empisal 760C overlocker : the left needle thread does not engage in the chain
Try replacing with a brand new needle and confirm that it is firmly and correctly installed. If it still will not engage with the looper threads, then you should probably take it for service.
Nov 22, 2016 | Sewing Machines
How to thread an empisal over locker ,DE-LUXE400
The manual should be helpful:
Empisal companion deluxe 400 user manual
It is always best to start out with brand new needles.
Before beginning to thread, be sure to ALWAYS RAISE the presser foot throughout the threading process. This releases the tension disks so the thread will seat properly.
Follow the thread order when threading or your machine will most likely never work properly. Usually, it would be the upper looper first, the lower looper next, and then the needles. However, your manual should clarify that. Also, when threading each, be sure to give each thread an extra little tug when it goes through the tension disk to make sure it seats correctly.
Empisal Overlocker Companion Deluxe 400 Manual downloadthefilenow com
Oct 15, 2016 | Sewing Machines
How to thread a Empisal overlocker.. model 760C
Perhaps the manual would help:
Empisal Overlocker 760C Empisal Sewing Machines
On most machines, it is important to ALWAYS raise the presser foot when threading the machine (although the instruction manual says to raise the presser foot only to pull the thread tail under it). Be sure to give the thread an extra little tug when going through the tension disk to seat it properly. Be sure to thread in the order as specified (Upper looper, Lower looper, Right needle, Left Needle). If the machine messes up, it is usually a best policy to remove all the thread and rethread from the beginning. Threading out of order will almost guarantee failure!!!
Jul 20, 2016 | Sewing Machines
Can one quilt on a S4D empisal overlocker
never had one but that would not be my choice to even try quilting
Feb 20, 2015 | Sewing Machines
Empisal 754D overlocker manual
try this link if they don't have a manual, then contact them to see if they can get one Empisal sewing machine instruction manuals
Mar 13, 2014 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
