I'm a appliance tech; and business owner in Virginia this GE harmony top load washer wpgt9350copl takes at least 5 min to fill on final rinse is this normal? Your feed back is appreciated.
  • 64 Answers
No 1 to 3 mins check screens on the water valve
Posted on Nov 04, 2013
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: ge harmony top load model wpgt9350copl washing machine
This is a very complicated machine utilizing no transmission, rotor/stator type drive motor, and a locking/unlocking clutch mechanism design to either engage or disengage the wash basket. These machines are tricky even for professionals to properly diagnose.
Posted on Jan 19, 2008
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
  • 47 Answers
SOURCE: I need a owners manual.
CALL GE AND REQUEST A OWNERS MAUAL. GIVE THEM YOUR WASHER MODEL NUMBER AND TYPE OF WASHER IT IS. GOOD LUCK.
RODNEY
Posted on May 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: GE WPGT9350COPL Harmony Profile-
The machine may be out of sequence. Unplug it for 40 minutes - then re-try.
Thanks!!
Posted on Nov 19, 2010
Why does my GE washer get stuck in Drain cycle??
for one G.E not a good choice mostly junk. the timer may indeed be bad if its sticking at 1 point and u can move it manually?
Feb 27, 2015 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
Kenmore front loader stops/freezes in pump out mode just before final spin
For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Aug 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
How do I set water temperature for the rinse cycle?
I suppose you have looked at the owners manual, on the page below, it seems to indicate knob B. but it is unclear
GTWN4250DWS GE 3 9 DOE cu ft stainless steel capacity washer GE Appliances
Dec 24, 2014 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
Hiw many gallons of water with 2 rinses does a top
Your washer takes 35 gallons to wash and 35 gallons to rinse. Ask me how I know? Well I work on them but last December my washer (which is the same as yours) developed a problem with the cold water inlet valve. My inlaws and daughter and friends all come by at different times to use paws paws washer. They pass 50 laundry mats to come to my house. Just for fun I told my wife to get a 5 gallon bucket and fill the washer up. It takes 7 buckets to fill the washer up and get it to start washing. Later she decided to run a water hose out to the washer and fill it up. Then my mother in law suggested she put the washer on rinse and fill the tub. That told me I had a timer problem. But luckily I have 2 or 3 washers around the house I can get parts off of. So to recap: 70 gallons of water to wash a full load of clothes is what I guesstamate it took. Did that slow down my inlaws? Nope.
Mar 05, 2010 | GE WHRE5260E Top Load Washer
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
RODNEY
May 12, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Won't Rinse
Had this same problem with my GE WBVH6240 Front Load Washer which we have had for about 5 years. After performing surgery on it; cleaning out the drain hoses, cleaning out the filter several times, checking the operation of the pump, checking the water pressure coming in to the washer, finally narrowed it down to the water valve. Ordered a new valve through Appliance Parts Pros. Got it in 2 days through regular shipping, installed it in less than 10 min, ran it through a quick wash cycle and everything works 4.0. Don't know which parts you replaced but this fix which I eventually got to only cost $50. Saved me hundreds and/or the possibility of buying a brand new washer. Hope this helps.
Dec 05, 2008 | Whirlpool GHW9100L Front Load Washer
Ge harmony top load model wpgt9350copl washing machine
Jan 19, 2008 | Washing Machines
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
