Question about Welding Tools
Cea monofil 200 welder starts without pressing trigger
As soon as the welder is turned on the welder starts to work , it feeds wire and gas without pressing the trigger
luxur4
  • 92 Answers
SOURCE: MIG wire is always hot without pulling trigger
Check your manual, there are a lot of mig units on the market that are alway "Live" alternatively, the relay has either shorted or you have wirering problem on the switch.
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Posted on Feb 20, 2009
SOURCE: NO WIRE FEED BUT WELDER CLICKING AS IF FEEDING
This could be caused by not enough pressure on the drive wheel. Try adjusting pressure as spelled out in you manual.
Posted on Apr 10, 2009
  • 5 Answers
SOURCE: northern tool mig welder,120 volt with gas.The
This welder is made in China. I have one and it works fine. Parts and service are available from northern tool. 1-800 # is on the book. FYI this 135 gas no gas looks exactly like the Lincoln SP135 and Lincoln workmate 135. GOTO the lincoln site and bring up the manual. It is a free download and is a much better manual than the one it came with. I agree with the previous post. Put a continuity test on the 2 wires that come from the trigger. there is a wire diagram in the book that came with it. Hope this helps.
Paul
Posted on Apr 28, 2009
SOURCE: I have a Hobart 135 Handler wire feed welder that
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
Posted on Aug 20, 2009
I have a craftsman 20511 mig welder it will start welding without pushing trigger
Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 934 205111 Operator Manual
commin problem with wire feed welder
Wire won stop feeding
May 02, 2016 | Craftsman Welding Tools
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
Why is my welder still feeding wire and gas after I release the trigger
Hey Dan, that would be a sticky or broken micro switc in handel if its a miller or Hobart you can replace just that part without buying a new handle .
Oct 18, 2014 | Welding Tools
Murex transmig 405s
The contactor that controls the power to the tip (the heavy one) may be fused closed This interupts power to the primary winding if tip goes live without wire feeding.
. It may also be a shorted SCR on the control board if wire is feeding or it can also be a fused feed motor contactor- the small one.
Sep 24, 2012 | Welding Tools
I have a hobart 135 handler that with machine plugged in and turned on the wire has constant juice and the gas cylonoid is flowing gas from the bottle without the trigger being pressed. my dealer said it...
Hi:
Have you disconnect the gun's power plug? If the wire and gas stop flowing by doing this action, then your problem is the gun's trigger. If the machine continues to feed gas and wire with the gun disconnected then yes, it is the pc board.
Good luck.
Aug 25, 2011 | Hobart Welding Tools
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
Try to short the trigger wire back closer to the unit or better still inside the panel somewhere. There is often a relay that is operated that allows gas to flow and power to the wire feed motor. Check where the trigger wire goes it may give you some idea. If you can identify the part you can source one and see if it worthwile repairing. Cheers
Nov 18, 2009 | Welding Tools
Will not feed wire when trigger is pulled. feed
1. Wire jammed
2. Out of wire
3. Not enough tension
4. Wire liner worn
5. Wire disconnected internally
6. Contact tip clogged
Aug 06, 2009 | Welding Tools
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
