Question about Dryers
Miele novotronic t699c super
After approx 30 secs dryer causes RDC to trip.
SOURCE: Not drying
I had the same problem with my dryer.
MAKE SURE THAT POWER IS OFF AND PLUG IS UNPLAGED AT WALL
On the back of the dryer there is a white metal cover in the centre with two philips screws. Once removed you will see metal box which has elements like a toaster built inside it.
You will see two sensors sticking out of top of metal box. The left one is the sensor for safety cut out in event of the dryer sensor on the right stopping working and letting the dryer overheat.
If you disconnect the left sensor 2 crimps and put multimeter on the left sensor two pins and if the meter beeps on continuety the sensor is ok. but if no beep the sensor is bad.
If sensor bad you can tempary bypass the sensor by joining the two cables together and try running dryer on a program and if heats up you know that you need to get new sensor.
WARNING! IF YOU LEAVE THE LEFT SAFETY SENSOR BYPASSED IF THE RIGHT HAND SIDE SENSOR MALFUNCTIONS THE TEMPERATURE WILL RISE AND CAUSE SERIOUS DAMAGE OR FIRE. THE PURPOSE OF THE RIGHT HAND SENSOR IS WHEN THE DRYER HEATS UP TO HEAT IT CUTS OUT AND WHEN DROPS DOWN IT HEATS UP AGAIN SAME AS AN OVEN.
You can maybe buy sensor from a meile dealer or RS COMPONENTS have the same sensor for £3.35 each.
NOTE: I ACCEPT NO RESPONSIBILY FOR DAMAGE OR INJURY IN MY ADVICE FOR REPAIR OF DRYER.
Posted on Dec 12, 2008
  • 163 Answers
SOURCE: Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
dmftrucker
  • 1922 Answers
SOURCE: Our miele condenser dryer with the miele washing
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Posted on Dec 07, 2009
  • 177 Answers
SOURCE: where is the reset button for the miele t200
there is no reset button for this unit. if it is not heating you may have blown your thermostat
Posted on Sep 05, 2010
TheMobilian
  • 8220 Answers
SOURCE: miele novotronic t230c condesner dryer rotates,
Probably a clogged condenser. With the condenser full of lint the dryers ability to work right is greatly diminished. Remove and clean the condenser.
These are relatively new in my area. I have posted Miele service manuals for washer and dryer HERE.
Posted on Nov 03, 2010
Hi there,my (quite old) miele novotronic dryer all of a sudden trips out all the electrics when switched on, any ideas?please help!!
not safe to use
will need an electrician
not easy to get some parts for that model
possibles
plug to wall shorted internally
older the dryer more reduction of wet clothes load required
motor or bearings tired
timer or heater element faulty
safety door switch faulty
Nov 02, 2016 | Miele Dryers
Miele T230C dryer keeps tripping out after only a few seconds?
Mostly likely cause is the heater element part no. 6138580. To ensure this does not happened again 1. Ensure appliance is situated in a cool room with ventilation (If room to hot it will not condense)
2. Ensure metal heat exchanger at bottom of appliance is rinsed regularly both long way and width ways.
Feb 01, 2011 | Miele Novotronic T230C Electric Dryer
Miele t494c start and then trip the fuse on main fuse box what is the problem
Had exactly the same problem. First, I tried with changing the plug - worked ok, but wasn't really the right solution. Then, cleaned with a high pressure washer (like the one you wash your car with). The result: no more problems!
Good luck.
Oct 12, 2010 | Miele Novotronic T240 Electric Dryer
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
It trips out the electrics
If your circuit breaker is warm when it trips. Then you need to replace the breaker. Need to know how to use a meter also.
Aug 11, 2009 | Miele Novotronic T230C Electric Dryer
No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Jun 26, 2009 | Miele Novotronic T230C Electric Dryer
Heating element
Thermal fuse
Wiring
Mar 21, 2008 | Miele Novotronic T220 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
