Question about Music
Peavey Manual for es-12pm powered monitor - Music
2 Suggested Answers
PolyrhythmFX
  • 109 Answers
SOURCE: Peavey signiture ES wiring
Go here: http://www.seymourduncan.com/support/wiring-diagrams/ and select your guitar's pickup/control/switch configuration from the dropdown menu.
Posted on Jun 20, 2009
I have an XR8300, two JBL 515XT (powered) for front of house and four 8 ohm passive boxes for monitors. What is the best way to connect all these to the Peavey mixer. Kaz
Feed FOH from Record Out, left and right. Feed monitors from the main outputs. That will give you the best option.
Aug 27, 2017 | Peavey Music
Manual for Peavey PV6 6 channel mixer
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Aug 05, 2012 | Peavey Electronics Peavey Pv6 6-channel...
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Feb 10, 2011 | Peavey XR 8600D Class D Powered Mixer
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
How do i connect 2 monitors to the one monitor output jack on the peavey xr 600c mixer..cheers My product not quite the one as listed from your product database but may be similar
The monitors will have to be POWERED monitors with built in amps.
You can simply use a wye splitter cable to drive the two monitors. Run the cable from the mixer to one monitor and put a wye cable and an extention to the second powered monitor speaker.
Jul 25, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Feb 23, 2009 | Peavey Music
Using Behringer PMP3000 to power monitors??
Using the mon out and the proper balanced cable follow the instrcutions found in the manual section 61.
Here is a link to the manual.
http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
Oct 04, 2008 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
48 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
