Question about Acer Computers & Internet
Acer ax 3960 wireless switch
Where is the wireless switch
Need to re-enable wireless to AX1430
Control Panel
Device manager
Network Adapter ->right click ->enable
All depends on your OS!
Mar 09, 2013 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
Need wireless adapter for Acer AX- 1430-EF30P
Come the case see if there is PCI slot in your Computer. As per my knowledge there is Two PCI slot in your computer which means you can add any PCI device, It can be PCI Wireless Adapter also.
Aug 17, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
How to sync afterglow ax.4 headset with xbox 360
how do tou fix the after glow ax.4.the problem whith it is that my freinds can hear me but i have to un plug it to hear them
Aug 03, 2012 | Microsoft Xbox 360 Afterglow Ax.4 red...
Language settings
Start - control panel - Region and language options - Language tab -
Dec 26, 2008 | Acer Aspire 6930-6771 Laptop
Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 20, 2008 | Toshiba SD-3960 DVD Player
My Toshiba SD-3960 sound does not work.
First thing before a landfill is to go into the units menu and see if something in the audio got turned off if not then inspect the connectors on the back for breakage. Good Luck
Apr 02, 2006 | Toshiba SD-3960 DVD Player
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
