Question about Maytag Neptune MDE5500AY Electric Dryer
My good friends just gave me a 5 yr old dryer. i installed it, turned it on, and doesnt sound like ot spinning the clothes, then it shut off after 5 sec, and it smells like something is burning. they said it was working fine when they gave it to me. they got rid of it only to move into a smaller home with a stackable unit.
  • Maytag Master
  • 8,220 Answers
Musta jumped the track when you moved it or sometimes a ball of lint gets in the blower and when they get moved the lint ball shifts.
To get into the dryer you first remove the door. Because the door is reversible you also remove screws on opposite side of door frame. Then you pop the goal post shaped fron panel loose using a putting knife starting up top. Then you can get the top up and remove the glide mount. Then you can remove the drum and clean her up. The fuse is mounted on the blower housing right next to the air temp thermister. Some models have another near the heater also. I have your service manual. It is at appliancejunkgoogledrive. http://www.youtube.com/watch?v=XM0raLH_-QE
Posted on Jul 25, 2013
4 Suggested Answers
honeymokey
  • 3113 Answers
SOURCE: the dryer smells as of something is burning and it is leaving a bad smell in the clothes
The dryer may be getting too hot. Check vent for obstruction from unit to outside.
Posted on May 25, 2009
  • 35 Answers
SOURCE: Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Posted on Sep 13, 2010
  • 121 Answers
SOURCE: 3yrs old stackable washer/dryer. The dryer doesnt
You might try going through the solutions listed here:
http://cincinnatiwasheranddryerrepair.com/diy-dryer-repair/5-when-your-dryer-wont-heat-up
Posted on Jan 30, 2011
Neptune dryer has power but will not spin.I hear a faint click comming from the left side. model#MDE9700AYM
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition.
The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
Oct 19, 2012 | Dryers
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
Maytag atlantis washer(spinning problem)
Your problem sounds like a broken belt . Check and replace. Good Luck Friend.
Jan 25, 2018 | Maytag Atlantis MAV6000 Top Load Washer
Dryer drum wont spin, it makes a buzzing sound when started for 3-5 seconds then shuts down. Drum is locked up, can't turn by hand.
soulnds like ewither something jammed betwween the front felt and the drum, or perhaps a small item of clothing has felll into the fan assy
Feb 09, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer won't stay lit
Dear friend,
ngfam at you service! happy to assist!
It sounds like a gas jet problem, or gas controller problem!
Please call factory service!
If the appliance is 10 years or older its not worth investing money to ix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Frigidaire Dryers
Dryer Gets Hot..But doesnt Spin
I don't know what kind of dryer you have, top or front loading, but it top loading it most likely is the belt that goes from the motor & wraps around the drum.
joel
Dec 21, 2007 | Malber TD700 Electric Dryer
2 dryers that run but have no heat
It sounds like the gas supply is not giving you any gas, as both have the exact same symptoms. You can see the glow coil getting red hot, then the safety shuts off after a it gets no gas. If you feel confident, shut off the valve in back coming from the wall, unscrew the line where it connects to the dryer. Turn the valve back on slowly, there should be gas pressure blow out of the line.
Dec 19, 2007 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
