Question about JVC AV-32D302 TV
Power, no audio no video
One day I tried to turn on my tv but only the power light turns on no audio, no video is it a fuse or something?
  • Anonymous Sep 15, 2008
    I turn the set on with remote and the power light lights, no video, no audio, but then I cannot turn off the set with either the remote or the front pannel on/off button.
  • 398 Answers
It is not a fuse, since if the fuse was bad, the power LED would not light at all. I have seen that symptom many times and I usually find 2 problems which cause this. On some sets, one of the larger caps in the power supply's secondary side degrades just enough that the set will not start. On other sets, I usually find that the small transistor that turns the relay on has shorted out, and the 11 volt zener diode next to it is usually shorted too. The transistor is a very small surface mount transistor, so the set should be serviced by a qualified tech experienced in JVC sets.
Posted on Aug 30, 2007
Thanks Mike
Posted on Nov 27, 2008
SOURCE:
My Seiki 48 inch flat screen won't even turn on. This is something simple like a fuse or something right?
TV won't turn on - Forums - CNET
https://www.cnet.com/forums/discussions/tv-won-t-turn-on-317367/
Nov 22, 2008 - 31 posts - ‎20 authors
I went to turn it on the other day, and it wouldn't turn on. ... reconsider going into something other than making tv and electrical products if .... LED power light will not come on, and no OSD/input willdisplay. ... I'm noticing two parallel issues with Samsung HDTV's not turning on, and since my TV doesn't even ...
Mar 21, 2017 | Seiki Televison & Video
LC-40le550u no picture... green light on
if powers on and has no video and no audio could be the main board, but first try this :
take a flashlight, turns on the tv and try to "see" the image while light up the flashlight against the screen , if you "see" something you have a bad back light inverter board.
below the posible parts number :
MAIN BOARD : Sharp 9JY0140CTJ05100
POWER SUPPLY/ BACK LIGHT : Sharp 9JY0940CTJ05000
TRY TO LOOK FOR AT :
www.bostonrecycling.net
or ebay
thanks
Oct 09, 2014 | Televison & Video
I have a pioneer DTS 96/24 multi-channel SX316 that just stopped working. Is there a fuse to try and replace? If so, where.
Remove the top cover and follow the mains cable into the unit. Any fuses should turn up near that. Make certain the power cord is out!
Sep 10, 2014 | Pioneer Audio Players & Recorders
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
Tried plugging something in :(flashing light.no pwr.
you have tripped the tv's safety power down feature, try unplugging the tv for 15 mins to an hour then try to turn it back on, if it still ceases to function, the tv will need servicing.
Oct 01, 2009 | Panasonic TH-50PX75U Plasma HDTV
SVA 42 inch plasma (HD4208TIII-PDP)sometimes turns on
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, justpress tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Mar 26, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
TV will not turn on
ok here in the philippines i think the cost of is 1500 php.is your tv turning light on? what light color? your tv has a atandby power light? are lights are blinking? if blinking please count it...
Nov 30, 2006 | Jensen TS2750J TV
JVC AV-32D302 TV Logo
104 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
