Desk top icons cannot be locked in place
I am using a Dell laptop computer which is hooked up via a docking staion to 2 flat screen monitors. The operating system is Windows XP service pack 3 The problem is that since late I cannot seem to arrange and lock my desk top icons in place. If I rearrange my desk top icons and then restart my computer they would all get moved back to the left of the screen in random order (not the way I want them to be). This is doing my head in as I have loads of icons on my desk top which I like to arrange in a manner that is easy to locate. Any help with this would highly appreciate. Thanks
Jkjkl
Posted on Jul 25, 2013
myterminal
  • 178 Answers
SOURCE: windows xp service pack 2
I think the screen resolution of your monitor have been changed.
To restore them back, you can go to display properties, from control panel and change the resolution under the settings tab.
Or
Your monitor settings can be made right from the buttons available from the outer panel if that is the problem.
Posted on Dec 01, 2007
  • 359 Answers
SOURCE: windows xp sp3 problem
Best answer is likely to uninstall and reinstall SP3. If it remains a problem, free support available from MS, as it is a Windows Update issue. Visit http://www.update.microsoft.com/microsoftupdate/v6/default.aspx?ln=en-us for more info. Thanks for rating FixYa!
Posted on Apr 21, 2008
  • 162 Answers
SOURCE: my operating system not uninstalled
Method 1: Use the "Add or Remove Programs" item in Control Panel loadTOCNode(2, 'moreinformation');
  1. Click Start, and then click Run.
  2. Copy and then paste the following command in the Open box, and then press ENTER: appwiz.cpl
  3. Click to select the Show Updates check box.
  4. Click Windows XP Service Pack 3, and then click Remove.
  5. Click Finish to restart the computer after the removal process is complete.
Method 2: Use the hidden $NtServicePackUninstall$ folder loadTOCNode(2, 'moreinformation');
  1. Click Start, click Run, type c:\windows\$NtServicePackUninstall$\spuninst\spuninst.exe in the Open box, and then click OK.
  2. When the Windows XP Service Pack 3 Removal Wizard starts, click Next.
  3. Follow the instructions on the screen to remove Windows XP SP3.
Method 3: Use the System Restore process loadTOCNode(2, 'moreinformation'); Note Before you use System Restore, make sure that you have restarted the computer at least one time after you installed Windows XP SP3. By restarting the computer, you allow for any remaining servicing processes to finish.
  2. Copy and then paste the following command in the Open box, and then press ENTER: %systemroot%\System32\restore\rstrui.exe
  3. Click Restore my computer to an earlier time, and then click Next.
  4. Click the date on which you installed Windows XP SP3, and then click Installed Window XP Service Pack 3 in the Restore Point box.
  5. Click Next, and then follow the instructions on the screen to remove Windows XP SP3.
Method 4: Use Recovery Console loadTOCNode(2, 'moreinformation'); Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
If you cannot remove Windows XP SP3 by using one of the previous methods, follow these steps:
  1. Insert the Windows XP CD in the CD drive or in the DVD drive, and then restart your computer. When you receive the following message, press a key to start your computer from the Windows XP CD: Press any key to boot from CDNote The computer must be configured to start from the CD drive or from the DVD drive. For more information about how to configure your computer to start from the CD drive or from the DVD drive, see the documentation that was included with your computer, or contact the computer manufacturer. You can also use a bootable floppy disk to start Windows XP. For more information, see the following Microsoft Knowledge Base article: (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP
  2. When you receive the Welcome to Setup message, press R to start the Recovery Console.
    Note Multiple options will appear on the screen.
  3. Select the correct Windows XP installation.
    Note You must select a number before you press ENTER, or the computer will restart. Typically, only the 1: C:\Windows selection is available.
  4. If you are prompted to type an administrator password, do so. If you do not know the administrator password, press ENTER. (Typically, the password is blank.)
    Note You cannot continue if you do not have the administrator password.
  5. At the command prompt, type cd $ntservicepackuninstall$\spuninst, and then press ENTER.
  6. At the command prompt, type batch spuninst.txt, and then press ENTER.
    Note The Spuninstal.txt file appears. As the file scrolls down, you will see errors and the files that are being copied. This is typical behavior.
  7. After Windows XP SP3 is removed, type exit, and then press ENTER.
  8. Restart the computer in safe mode. To do this, press F8 when the computer restarts.
    Note After you restart the computer, the computer may stop responding, and you may see a black screen. The mouse will work. In this case, restart the computer again by turning the computer off and then back on. The second restart will let you log on.
  9. When the computer restarts, Windows Explorer (Explorer.exe) does not run, and the Windows icons and the Start button are unavailable. To resolve this problem, follow these steps:
    1. Press CTRL+ALT+DEL, and then click Task Manager in the Windows Security screen.
    2. Click File, and then click New Task (Run).
    3. In the Open box, type regedit, and then click OK.
    4. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\RpcSs
    5. In the details pane, right-click ObjectName, click Modify, type LocalSystem in the Value data box, and then click OK.
    6. Restart the computer
  10. Use one of the previous methods to remove Windows XP SP3 from your computer.
Posted on Nov 25, 2008
SOURCE: themes for windows xp-desk top download free.
i cant connect to YM due to 81003004 error.....
Posted on Jan 23, 2009
early1234
  • 871 Answers
SOURCE: Windows XP Home Edition Crashed After Loading Service Pack 2
hey coco
nothing happens when you try to use the recovery console right by pressing "r".
try this again and again , sometimes it idles but its still running, if the error appears, restat again.
some corruptions maybe beyond our control and sometimes the only solution for this is to recover the inportant files you have on that HD and do a reformat...
Posted on Jan 24, 2009
Dell D620 laptop screen won't come on after disconnect from docking station
please use the following small secret. Disconnect the power adapter from the laptop.
2) Dissasembly the batteries from the laptop.
3) press the power button in ON with the adapter+battery disconnected from the computer. and maintain press the power button by EXACTLY 60 seconds.This liberate the ESD.
4) Try again.
God bless you
Mar 05, 2013 | Dell Latitude D600 Notebook
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
Hi, I have an LG Flatron L227WTG monitor. I have 2 computers on my desk. When I plug the monitor directly into my home computer, the monitor works just fine. When I plug it into my work laptop (via a...
Hello, maybe you've got to switch the output from your laptop screen to the external screen, if so, it will be by pressing and holding down the Function button and at the same time pressing one of the Function keys (at the top of your keyboard). On mine, (an HP) it's F4, but you'll see a symbol on the correct key that looks like a screen. Regards, nicam49
Jul 13, 2011 | LG 22" FLATRON LCD Monitor
How do u connect a ei53fp monitor to a 1336 by 768 reolution laptop
Attaching a second monitor to a Laptop, if its fairly new, will automatically load a second display. Right click the background on your LAPTOP screen and select properties after you attach the monitor cable. Go to settings. You should see two monitors. If not, you need to press Fn+ F6 on most Laptops to activate the second monitor. See your owner's manual on function key (Fn) Choose the second monitor screen and set the desired resolution.
Apr 17, 2010 | Dell E153FP 15" LCD Monitor
Hook up dell laptop to docking station: I have a dell lap top inspiron 1721 and a dell model # PRO1X docking station, I would like to hook it up in my home office. I have never done this before and just...
this is easier than you think my friend, firstly put the dock on your desk, plug in power lead, network cable and monitor cable, place laptop on dock (making sure it clicks into place) turn on dock and monitor and your up and running
Oct 16, 2009 | Dell Inspiron 1721 Notebook
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
I just bought a docking station for my Dell laptop computer. How do I hook it up so I can keep the top closed and use my desk top monitor? I want to be able to turn on the laptop without opening the lid.
Well.. you'd still have to open the lid to turn it on, right? (because you didn't mention the model of your laptop, I don't know where the power button actually *is*)
You want to close it while it's on, without it hibernating or going to sleep...
Go to your control panel, then into power or power management (depending on your Windows version, because you didn't mention it)
Then have a look under the "advanced" tab where it asks "when I close the lid of my computer". Set that to "do nothing".
Now when you close the lid, the laptop screen should turn off, but the PC should keep running. I'm not sure if that will still turn your external monitor off though.
I think that is your best solution, other than hacking off the little button that senses when the lid is closed. =-]
Aug 23, 2008 | Computers & Internet
Dual Monitor Color/Brightness Differences
Correct the resoulution is not the same. Also you are using 2 monitors and using the system to power these great displays. Just dont hook up a docking station. The picture gets really bad..
Feb 13, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
