Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
Hi, I have a Westinghouse Wse6100WA side by side Fridge. The fridge compartment is not cooling properly and the freezer is icing behind the panel inside the back of the freezer and then visibly inside the freezer as well. The more iced up it gets-the temperature goes up. Any help would be greatly appreciated. Westinghouse aren't helpful at all. I am in Australia so may be different model code in other countries. thanks.
  • 5 more comments
  • maki_jc73
    maki_jc73 Feb 18, 2014
    Hi Nighteyes, I recently had the same problem which you describe above last Dec 2013 and after googling for solution as it cost a fortune to call a fridge man service. Check the vent in the fridge for our model which is located next to the 1 top crisper box. A lot of ice is blocking the cold airflow from freezer to the fridge. So I defrost the fridge and let the ice melt until I can't see ice on the vent blocking the airflow. It takes awhile so I use blow dryer to speed it up. It now cools my fridge. Our model is a frostfree cycle so which should take care of itself. This method fixed up the problem. However, now it is too cold that it freezes meat and vegies, any liquid in my fridge.
  • maki_jc73
    I rang up Electrolux and she advise that make sure no item is blocking the vent (fridge - next to the 1st crisper box) and thermostat in both fridge (above the 1st box crisper) freezer (3rd shelves from the top - looks like a bar). Mine is clutter free. So they advise to change the settings to manufacture setting in Freezer (-18 C) and Fridge (3 C). I googled the symptoms and found explanation which you can try if you get my 2nd problem. Link:http://steveomc.hubpages.com/hub/Refrige... and link:http://steveomc.hubpages.com/hub/Do-It-Y... *Note settings takes at least 24 hrs to balance the settings & must be done in small increment and wait for 24 hrs. Refer to suggestion in the article. I have yet to fix my 2nd problem but have taken the steps of setting it back to manufacturing settings right now. Hope this all helps! Hope you don't get my 2nd problem.
  • maki_jc73
    With my 1st problem, perhaps I have not defrost long enough. I turned it back on when I can't visually see the blocked up eyes on the vent.
  • maki_jc73
    now will try cralton's solution below.
  • maki_jc73
    by the way, i have now fixed up my fridge being "too cold" by setting the fridge to manufacturing setting as mentioned above in my earlier post (i.e. Freezer (-18 degrees Celsius) and Fridge set to (3 degrees Celsius). Yay!!! I just saved myself $334 ($134 call out fee and if thermostats needs to be replaced it is $200). Hope this helps those who are looking for answers. Save those two website link I posted as it helps you better understand how fridge work. I am a lady so if I can do it so can you. *wink :-)
  • maki_jc73
    Yay!! I fixed the problem of my fridge from being too hot to too cold to normal temperature now. I simply reset the fridge and freezer back to manufacturing settings as mentioned in my previous post above today. Freezer (-18 degrees Celsius) and Fridge to (3 C) for this model which is digital control. It would normally takes 24 hours for the settings to be in balance. In my case it took about 4 hours to see the result. Finally I can use my fridge again. Hope this helps for those who have similar problem. My recommendation is to save those two web links i posted previously above to get an understanding of fridge and how it works. I am lady if I can do it so can you. *wink ;-). All the best!
  • maki_jc73
    Oops they deleted my answer to your original symptoms of fridge not cooling. check the air vent as it is blocked with ice. and it worked for me but it turn into too cold that freezes my vegies. my solution for that is my last post above. keep this web links handy. Links:http://steveomc.hubpages.com/hub/Do-It-Y... Link:http://steveomc.hubpages.com/hub/Refrige...
    New Friend:
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Posted on Feb 20, 2010
  • maki_jc73
    Thanks for the tip! I will try your method too.
  • 358 Answers
Could be the fan that brings cold air from the freezer to the fridge dont work or the defrost system inside the freezer wich is the defrost heater the timer or the defrost termostat ,most cases is the timer.
Posted on Mar 31, 2009
  • maki_jc73
    with WSE6100WA model, i suspect after reading my article link posted or Nighteyes13, that my 2nd problem is most likely i defrost what is visible to me in the vent but there could be more eyes down the tube that I can't see. which means i have not defrosted enough and turned it back on. this means the defrost thermostat is not working properly to freeze all my food after fixing my first problem. thanks for tip. if it is the timer, any suggestion for the fix? or we need to get service man to fix the timer?
SOURCE:
Food freezing in Refrigerator Freezer ok. Westinghouse model wse6100wa. Have misplaced manual and need to know what temperature is correct and how to fix this problem.
There is a normal setting of the thermostat for the fridge and freezer and you can select the fridge setting to be lower than normal than what is set presently.
If there is no change then the thermostat is not cutting off the cooling and so there is no control of temperature within the fridge. Allow the lowest setting of the thermostat in the fridge section to confirm this fault.
Aug 18, 2011 | Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
Hi there.I have an Amana Side by Side Refridgerator.We are having a problem with the fridge side not cooling enough.The Freezer side is working well.Have you any tips on how to fix it myself ?Cheers.
Check fan which blows cool to fridge compartment is working. Check fridge is defrosted automatically. If not do it manually and check, there will be cooling in fridge compartment. Over frosting will cover up the fan throw behind the freezer. If not auto defrost works, switch off and restart after 5 minutes. Still auto defrost problem, do it manually or replace board.
Jan 27, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Liebherr KBES 3650 - too warm in main fridge compartment. Hi the main fridge compartment of this larder fridge warmer the it should be (milk does not taste as cold as it should). The temp...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Liebherr KBES3650 Stainless Steel...
Westinghouse model RS663T - not cooling fridge or
IT IS THE DEFROST THERMO STAT REMOVE REAR COVER AND MELT ICE IT IS ROUND SILVER PART
Jan 31, 2010 | Refrigerators
My westinghouse sid-by-side fridge is freezing
the mother board located inside the lower rear portion of the unit is bad,if you have recently had lights blow out this can cause a surge and ruin the mother board,also if there are relays clicking and lights are blinking dimly this is a good sign the board is bad
Jan 16, 2010 | Refrigerators
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
2,633 people viewed this question
Top Westinghouse Refrigerators Experts
Ekse
Vincent G
Vincent G
Sheldon Dedek
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
