Question about Onkyo Audio Players & Recorders
ONYKO HT-RC460 receiver replace fuse - Onkyo Audio Players & Recorders
Reciever has no sound
Check the rear fuses.
May 25, 2014 | Onkyo HT-RC460
No power
  1. TURN OFF THE DEVICE AND POWER SWITCH FROM SWITCH BOARD UNPLUG THE MACHINE SAFELY
  2. check for cable going from switch to the machine for any wear and tear
  3. WARNING DO IT AT YOUR OWN RISK BECAUSE IT WILL BE SERIOUS HAZARD AND YOU CAN GET SHOCKED PLEASE LEAVE THE HT ALONE FOR 5 MINS AND THEN DO THE PROCEDURE
Apr 05, 2014 | Onkyo HT-RC460
Can you install two powered subwoofers to an onyko tx-sr 608 receiver 7.1
get an rca y-splitter for the sub out, and you can run a signal to 2 subs
Mar 23, 2013 | Onkyo TX-SR608 Receiver
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
I have a ONYKO HT-S3300 unit that has a message of "no signal". Television is not coming on. What's up?
Possible there is no input signal , please check your source, if Antennae, Cable or X-box. Test with another input - a DVD player to confirm the TV . If so the tuner or the allied circuit can be faulty.
Feb 19, 2011 | Onkyo Audio Players & Recorders
I have an Onyko receiver and am trying to hook up a Samsung DVd player to work on the Onyko remote. The 2 codes provided by the booklet do not make the Samsung work. Wondering where or how to get updated...
The intruments of onkyo receiver does not matches with the samsung dvd player.Since samsung dvd players have thier own remotes with the matching software. samsung receiver can have the codes matching.
Jul 26, 2008 | Televison & Video
Center speaker will not work
If you had the Speakers Set to A (not B) and no headphones connected when you pressed the TEST TONE button on the Onkyo HT-R540 (also known as the HTS-790) remote, and you had no sound from the Center Speaker then try the following steps. 1) Check the Center Speaker wiring at both ends under a bright light and make sure that there is not a strand of wire touching the Receiver Chassis or another speaker post. Check both + and - . If that looks okay, 2) unscrew the Center Speaker Post connections on the Receiver and verify that the bare stripped wire is making contact. Often, the insulation is too far into the connector. When screwed down, the wire's insulation is crushed and keeps the bare wire from making contact. If this looks okay and the unit is under Warranty, your last test is to: 3) temporarily swap the wires from the Center Speaker with the Right Front Speaker. Turn the volume down low and try the TEST TONE button again. If you now hear sound from the Center Speaker box itself and none from the Right Speaker box, then the Receiver is the problem. If you still do not hear sound from the Center Speaker box, then the Center speaker itself is defective.
Sep 25, 2007 | Televison & Video
98 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
