Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Electronic Relay Control
Model Cgef304dkf2 Error F20 indicates ERC needs replacing. My problem is locating the board There are two boards (lower) and one board (upper behind panel) Not sure which board to replace
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon C, error code F20 does indicate part replacement on the ESEC-UIB (User Interface Control), located behind the console on the side of the actual display. I would recommend, however, running a quick test to ensure that this is not a false error code. You do this by resetting your oven by flipping the breaker or unplugging the unit for approximately ten minutes. If resetting the unit does not correct the issue, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Posted on Jul 25, 2013
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
My oven flashes F3 and F2 error codes while on
Both of these errors mean that your control board thinks that your oven sensor is shorted. This is either a bad oven sensor or a bad display relay control board. You can't test the board but you can test the sensor.
Open the door and remove the 3-4" long thin metal rod attached to the back wall. There are 2 screws holding the sensor on that you can remove and then pull the sensor forward until you can disconnect it. WIth a multimeter, check the resistance of the sensor at room temperature and it should be about 1080 ohms. If it's not, replace the sensor, otherwise you need to replace your relay board.
The Electronic Range Control (ERC) senses the oven temperature by the resistance of the oven temperature sensor. As the temperature goes up the resistance of the sensor increases and the ERC converts the resistance to degrees. Sometimes the sensor fails and gives high or low resistance readings. Sometimes the ERC fails and calculates the temperature wrong. Sometimes a relay on the ERC sticks and the temperature goes too high. Sometimes there is a bad connection between the sensor and the ERC causing high resistance and the ERC thinks the temperature has gone too high.
Hope this helps.
Jun 07, 2011 | Ovens
Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Oct 26, 2010 | Kenmore Ovens
Whirlpool oven with the error showing E1 -F2- how do I fix it? model: RBS245 PDQ
This indicates the keypad or ERC electronic range control has failed.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 17, 2010 | Ovens
I have a free standing stove/oven, model #790.94111402, Serial # VF51340715. The display shows "Erros F10". Please help.
Hi
Thanks for using FixYa. F10 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Kenmore Ovens
Amana convection. Showing a F1 code on the panel. Model ARTSC8650WW
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Amana Ovens
Ge built in 1993 oven shows an F-1 sign and beeps
Hello there:
any time you recieve the f-1 and sometimes a f-o error with the beeping this is from the electronic range controle board or erc for short and this means that that part has fgailed and needs to be replaced if you go to repair clinic.com you can look up you oven model number and get parts from there or if you have a appliance repair center in your home town give them a call and tell them the ovens model number and tell them you need a erc or electronic range controle board ok?
Hope this helps
Best regards Michael
Aug 16, 2010 | GE Ovens
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
OR....
OR
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
175 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
