Question about Sylvania LC195SLX LCD TV
Gets no signal on coax, works on HDMI
Autoscan finds no channels with coax cable attached. HDMI and RCA inputs work OK. Is this the main board w/coax connector gone bad? How do you remove/replace the cables that attach to this board??
    Top Expert:
  • Sylvania Master
  • 74,383 Answers
Check and replace its tuner.
Posted on Jul 25, 2013
5 Suggested Answers
SOURCE: TV not working with remote from Cox cable/Scientific Atlanta
Try the code 052.
Posted on May 18, 2007
SOURCE: In my Sylvania LD320SS8 A the picture is beeing
If you have a cable box attached to the tv, check the "aspect ratio" on the cable box. there should be a button on the remote for the cable box. this may solve your issue.
Posted on Jan 31, 2010
SD Tech
  • 14553 Answers
SOURCE: attempting to connect the HDMI cable from the computer to the TV ( model LC320SL8) I'm not getting a signal or any sort of feedback. just a black screen. i once had the tv hooked up to my laptop a
HDMI can be flaky and does not like things to be connected while units are powered up---tv or the unit being connected.
If you hooked up with set on etc the set may not of "seen" this event and refuses to function. I know it sounds odd but I have seen this many times.
Posted on Oct 30, 2012
  • 127 Answers
SOURCE: I have a sylvania LD155SC8 and can't get it to get a signal. DVD works great. What gives?
Did you test the signal with another set?If so you may have a tuner
problem or a power suply, check the fuses.
Posted on Nov 05, 2012
I have a hdmi rca tv, unhooked the digital cable box for awhile went to hook it back up and can't get any channels scanning picks up nothing what should I have the setting set to? Hdmi set to cable
If you have a cable box the channels are selected via the cable box remote and the TV is set to an HDMI video input. The specific input is identified where the HDMI cable connects from the box.
Use the video input remote to select the HDMI for the cable box.
Scanning is for identifing the over the air stations that use the coax input noted as antenna (ANT IN) on the back of the set.
Hope this helps?
Mar 13, 2016 | RCA Televison & Video
U-verse will not show on guide plus rca
its not always going to be channel 3, it depends on the input cable you are using, if you are using an HDMI cable you need to switch to the hdmi input, same with component, and if you are using RCA cables it will probably be called video. Try your other inputs dont just stop at channel 3. If you are using coax and its supposed to be on channel 3, make sure you are on the correct coax jack on the receiver, make sure its the "to tv" jack not the "to wall" jack.
Apr 14, 2013 | AT&T UVerse
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
My sub will not work when input is tv/cbl. it works for DVD and CD. My cable box says the signal is Dolby 5.1 but receiver does not show that mode. using RCA jacks for connections. Used to get 5.1 and sub...
hello,if your using rca plugs from the cable box than dolby digital 5.1 will not be present. You need to use either an optical or coax or hdmi cable from source to the reciever to recieve digital audio.
Dec 07, 2010 | Denon AVR-2308CI
Problem for Sylvania LC195SLX LCD TV Channels will not program in tv.check with different tv it works
It looks like your TV doesn't have a digital tuner in it. Without that you won't be able to receive any broadcast television stations. The spec sheet is here: LC195SLX the tuner is listed as just ATSC/NTSC - not digital. You will need a cable or satellite box to receive stations.
Jun 14, 2010 | Sylvania LC195SLX LCD TV
I just got a new tv, and have hooked it up to my Directv receiver per their phone helpdesk person's instructions. I can't get the channels to auto-program on the tv - it keeps telling me there's no signal....
How are you connecting the receiver to the television? RCA cables? HDMI? Coax cables?
Auto tune only works if you are connecting via coax and plan to use channel 3/4 to view. If you are using either HDMI/Coax/Component/etc, then you would need to use the input button on your television remote (Not the DirecTV remote, the one that came with your television) to toggle through the various inputs until you find the signal from the DirecTV receiver.
Feb 24, 2009 | Directv RC23 Remote Control
Humm coming from speakers - can't get cable to work
The RF input is the correct one for a cable signal. The other sources use the RCA and other ports which you can connect to other devices, like DVD or VCR players.
If the humm noise only happens when you're on the TV channel then it's likely just the station. Try changing the channel and see if that helps, and make sure the coax is screwed in all the way. Also make sure the other end, if connected to a VCR or other stuff, is tightly attached. If you share cable with many other people and the signal has snow (white spots on the TV), then you may need to buy an RF signal amplifier to reduce the noise.
Source changes the input (RCA versus coaxial versus component inputs), change the channel for different channels..
Jan 31, 2008 | Akai LCT2701AD Television
HDMI input problems
HDMI is suppose to carry sound. With the rest of the symptoms you describe, the first thing I would try is to replace that cable with a good quality one.
Mar 26, 2017 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
Sylvania LC195SLX LCD TV Logo
85 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
