Pdl common file are needed for hp laserjet p2015 printer
Pdl_common file are needed for hp laserjet p2015 printer
  • 300 Answers
SOURCE: Meter read on HP Laser Jet P2015
To print a Configuration page from the printer, press
and hold the Go button for 5 seconds
Posted on May 16, 2008
SOURCE: Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Posted on Dec 03, 2008
taran_2005
  • 10515 Answers
SOURCE: hpc20155.xml is needed. i don't know why this
You have to end a .inf file from Microsoft to get it to work. Open up c:\windows\inf\oem16.inf in your favorite text editor. Search for "hpc20155.xml" and you will find this section:
;hp LaserJet 2015 files
[DATA_FILES_20155]
hpc20155.xml,,,0x00000020
hpzsc43e.dtd,,,0x00000020
hpc20155.gpd,,,0x00000020
hpc2015b.ini,,,0x00000020
Change hpc20155.xml,,,0x0000002 to hpc2015.xml,,,0x00000020 (take out the last 5 in hpc20155.xml). Save it and go back to add a new printer in windows. This should fix the problem.
There is one thing to add, however: the name of the oem inf file might be slightly different on different computers. Easiest way to find it is to go to Start –> Search –> Files and Folders; Set your search location to C:\Windows\Inf, and enter “hpc20155.xml” in the field labeled "”A word or phrase in the file”. If you get multiple results, you’ll have to check them one by one; just follow the rest of the bjones’ walkthrough from that point on.
Thanks.
Posted on Jul 01, 2009
bmni
  • 3 Answers
SOURCE: hp laserjet p2015 printer showing jam & toner
This problem is not initilize the printer. so i change the formater board, now its workinfg fine
Posted on Oct 05, 2009
HP LaserJet P2015 Printer Cannot pick papers
Your paper pick-up roller is possibly broken and needs to be replaced, ( common occurance),the shaft that turns your paper pick-up roller could also be broken, it is on the right side of the pick-up roller, but this is not as common.
Good luck
Feb 21, 2011 | HP LaserJet P2015 Printer
Hi ...i need a driver for window 7 for printer HP Laserjet P2015 series PCL6
Drivers and software for HP 1020 can be downloaded from HP official site. Choose you operating system and download the required files
Select 32-Bit or 64-Bit depending upon the version you have.
Good Luck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 15, 2010 | HP LaserJet P2015 Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
Install HP LaserJet P2015 Printer
Click Here for your hp p2015 driver, input your operating system and it'll give you the appropriate driver for that system. hope this helps and if so please mark a FixYa!!
Aug 24, 2010 | HP LaserJet P2015 Printer
Hp laserjet p2015 printer driver needed
Hi
Thanksfor using FixYa. Please choose the Windows you are using and download andinstall the printer drivers from the link---
HPLaserJet Printer P2015 Driver
Please do rate the solution if the issue isresolved or post a comment for further assistance.
Thanks
Rylee
Jun 05, 2010 | HP LaserJet P2015 Printer
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Sep 07, 2009 | Office Equipment & Supplies
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
Install my printer without installation CD
just download :
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=1814092
Thnaks,
Mukund
einfochips
May 15, 2009 | HP LaserJet 1018 Printer
677 people viewed this question
jasbo
jasbo
