Question about GE GSL22JFXLB (22 cu ft) Side by Side Refrigerator
GE Icemaker My icemaker is making ice but when I push the button there is a clicking noise in the back and nothing happens. Ideas?
    Sergeant:
  • 304 Answers
Switch sounds like its sticking. Micro switch needs to be replaced
Posted on Jul 26, 2013
  • 4 Answers
SOURCE: Ice maker stopped working
Just a question... Is the motor that flips the ice down into its tube moving? or spining? your motor in the ice maker may have went out. might have to replace it.... hope this helps....
Posted on Jun 20, 2008
eagle338
  • 4889 Answers
SOURCE: Click in circuit board Light in Icemaker dim bright Warm both sides
I didnt understand what you meant by refer(refrigirator???) and IM..??
Posted on Jun 26, 2008
peyton32034
  • 410 Answers
SOURCE: icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Posted on Jan 22, 2009
tborn6
  • 700 Answers
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Posted on Jan 30, 2009
ginko
  • 19396 Answers
SOURCE: ICEMAKER LEAK ON GE TFX25VR
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Our GE side by side fridge isn't making ice. The arm in the ice maker starting clicking in the middle of the night and my husband just went into the freezer and held the arm up for a few seconds. The...
    It sounds like you have a bad icemaker. Usually when the arm is clicking its the gears that are stripped out. Feel in the icemaker if theres cubes frozen in there then you know the icemaker is definitely bad. With the arm in the up position it will not make cubes at all that is the off position for the icemaker. Hope this helps _MJ_
    Apr 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE side-by-side: freezer making grinding noise. Husband unplugged and removed icemaker. What was the problem and can I fix it myself?
    did it sound like someone snoring in your freezer? that is your icemaker trying to eject cubes, and that noise in and of itself, is nothing to be worried about, that is normal. however, if your icemaker was failing to produce ice, when your husband removed the icemaker, was it near overflowing with ice, or did it look like it just had what would be a normal amount, i.e., the ice in the mold was little more than helfway. if it seemed like it was a normal amount of ice, then the heater on the bottom of the icemaker failed, replace the icemaker. if you had an abundance of ice in the icemaker, you may have a problem with either your water vavle solenoid not closing completely, or the icemaker motor itself is slow, causing the valve to be open too long. without checking it personally, i cant advise either way
    Feb 15, 2010 | GE Refrigerators
    Hi, our GE icemaker is making a noise. it
    You can try turning off the ice maker switch , then back on , but the ice maker is electronic . If any internal damage is done , replacing the ice maker , will be the best solution .
    Dec 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE side by side CAN17 ice maker...white ''finger assembly'' that pivots has broken two fingers, and the ice cubes are stuck in the cube dispenser. Any ideas why this happens, and how to fix it without...
    You will need to replace the icemaker. The sensor that activates the heat coil in the icemaker is bad. The heat sensor allows the cubes to be released from being frozen to the ice tray. Check ebay for a new icemaker. About one third the price of manufacturer for new factory unit.
    Oct 27, 2009 | GE Refrigerators
    Testing IM-6 Water inlet valve
    check water valve or icemaker
    Apr 06, 2009 | GE Refrigerators
    Ice maker not turned on or hooked to water line
    it my be not the icemaker check fan or you can remove icemaker
    Feb 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Icemaker just stopped making ice
    As these ice makers cycle there is an arm that moves up while the ice is being freed from the ice maker. After the ice is dumped into the dispenser bin the arm continues a downward motion. If it encounters ice in the downward travel it shuts the ice maker off. If this arm is locked in the full up position the ice maker is manually shut off. Check this arm and make sure it is not locked in the up position.
    May 15, 2008 | GE PSS26MGS Side by Side Refrigerator
    Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
    reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
    Feb 13, 2008 | Refrigerators
    GE GSL22JFXLB (22 cu ft) Side by Side Refrigerator Logo
    75 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
