Question about Amerec Steam Shower Generator Single Unit 5037 kW Steam Generators ASG
Amerec E055 What does this mean on a amerec Steam Generator 9KW Unit
Sauna wont get hot enough
When I'm in a traditional sauna like this, I expect the temperature to be between 70 and 90C so that's what I assume you are trying to reach. There could be several reasons for this so make sure each point is checked:
1. Stating the obvious, to increase the temperature inside the sauna, you'll have to ladle water onto the hot sauna stones.
2. Maybe the insulation within your sauna isn't good enough and heat is escaping.
3. Your sauna room could be too big for this heater to heat properly.
4. Maybe the element on the heater isn't performing properly and needs to be replaced.
These were some pointers which Di Vapor gave as possible reasons for lack of heat.
Sauna Electric Heaters Spares
Feb 15, 2014 | Amerec 4.5KW Heater w/ Built-in Dial...
What kind of water is to be used in the steam station RHST 100. I mean to say that only distilled water is to be put or ordinary tap water can be used ?
hi.
distilled or de-ionised water is recommended in all steam generator units.
tap water can contain minerals and salts that will remain in the unit and fur the inside of the steam generator.
if you live in a soft water area where there are very few impurities in the water you should be ok to use the tap water.
if you are in a hard water area, do not use tap water.
the best way to work it out is look at the inside of your kettle.
if the inside is clean with no sign of scaling, the water should not scale your steam generator.
if there is any sign of scaling, do not use tapwater for your steam generator.
distilled or de-ionised water is recommended though
Apr 08, 2011 | Vacuums
We just moved into a house with a MS150 Mr steam. I turn it on and the display reads 110 for 10 mins then comes up with H2O on the display. What do I have to do? Nothing seems to happen.
Hi my name is Mike with Mr. Steam please give me a call at 1-800-767-8326 and ask for tech support. We will need you model # and SN # that is listed on your unit if you can be by your unit when you call and we will help troubleshoot your unit. In the mean time check the following 1) water is on 2) drain valve closed even if you have a auto flush close manuel valve for testing
Thanks
Mike Nail
Mr. Steam
Sep 18, 2010 | Mr Steam MrSteam MS150E Steam Generator
Crank Bearings
Call Accel Fitness of North America they the distributors of Tunturi Fitness. call them @ 1-888-388-6887
Mar 13, 2010 | Tunturi T30 Programmable Treadmill
I just bought a house with an amerec sauna. The
the 'easy' answer would be a tripped high-limit switch. Inside the generator box, there is a resettable circuit breaker to the heating element, on the top of the water tank.
kill the power to the unit, take off the shell and look for the pushbutton.
If that is the problem, there is a likely chance that the temp sensor in the shower is not working so it overheats and trips the high temp limit.
Dec 22, 2009 | Kitchen Appliances - Others
I have a Kohler K-7 steam generator/shower and after using it just fine, water now just pours out of the steam outlet - even if the unit is turned off at the control head. I have had to close the inlet...
There is a float valve interior of the steam generator that supplies water to the generator unit. There are no parts available for that unit, and Kohler was useless re: repair. I have the same unit and mine is doing the same thing. I took it apart and there is a washer worth about a nickel that is inside the unit. I flipped the washer over in mine and it worked for about a week....then back to the same problem.
Dec 05, 2009 | Kohler K-1698-G Brushed Chrome Tandem...
Steam generator will not activate- thermasol model ASD300A
how do you know the unit has power?
what control do you have?
does it light up.
Mar 15, 2009 | Thermasol Steamshower Generator AF Series...
Amerec Steam Shower Generator Single Unit 5037 kW Steam Generators ASG Logo
67 people viewed this question
Top Amerec Electrical Supplies Experts
Steve
Gene Haynes
Are you an Amerec Electrical Supply Expert? Answer questions, earn points and help others
