Question about Mtd Garden
14.5 HP MTD MOWER WON'T TURN OVER
My 14.5 hp mtd mower died and it won't turn over. I replaced solenoid cause someone said if I made contact with both post on solenoid and it turned over that it was a bad solenoid. Not true in this case. Someone bypassed the seat safety switch. Wires are hanging and looks like something is missing in area next to solenoid. This hasn't kept it from starting before.What else can I look for?
    New Friend:
    Problem Solver:
  • 11 Answers
Can you turn the motor over by hand? Make sure it's free and can turn. Is starter drive engaging into flywheel. If mower was run with low oil or on a slope it may have seized up.
Posted on Jan 06, 2014
  • 376 Answers
SOURCE: Poulan Riding Mower won't crank, battery OK.
Forget the safety switches for now.The first thing I would check would be the fuse. It will be located on the battery side of the solenoid. Follow your positive battery cable to the solenoid. There will be a small red wire coming off of that post with an inline fuse. If the fuse is good, check your solenoid. There are two wires plugged into spade terminals at the bottom of the solenoid. Unplug the one that is insulated, the other one is a ground. Hook a test light from that wire to ground. When you turn the key to start (with the brake pedal held down), it should light. If it lights, your solenoid is bad. If not, then you can start looking at switches. Probably will be one of the two. Hope this helps. Dwain
Posted on May 21, 2009
SOURCE: MTD RIDE ON LAWN MOWER SOLENOID
CHANGE DRIVE BELTS
Posted on Nov 09, 2010
  • 14 Answers
SOURCE: John deere Z225 riding mower
measure with a valt meter and see what your voltage is at the battery . now measure what you have for volts at the soleoid. then check to see if you are getting 12 volts to the single peg on your soleoid, usually a whitwe wire. If your not getting voltage to this wire you probably have a safety switch problem. If you are getting voltage here check to make sure you are getting voltage at the starter motor. If your getting voltage there you may have a bad ground at the starter motor or the whole motor may need to be grounded to the frame.
Posted on Sep 12, 2011
  • 57 Answers
SOURCE: My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Posted on Apr 04, 2012
Testimonial: "I finally got it started after draining the gasoline out and replacing with new gas. It only runs with the choke engaged, but I'm going to seafoam the carburetor and add it to the gasoline."
  • 6468 Answers
SOURCE: MTD Ranch King Mower won't start
check the safety switches bypass them with a paper clip to test them
Posted on Jul 16, 2012
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
How do you find an inline fuse for a mtd riding mower 38 inch cut 14 horsepower
Start at the ignition switch and look for the starter wire..it should be the one tat is slightly heavier and normally red..and goes to the solenoid pos side..good lu k
Nov 16, 2014 | Mtd Garden
Cub Cadet Riding Mower LT 1046 have to jump, but won't stay running
Check the bottom of the carburetor for a little solenoid. If it has one, the battery may be dead enough that it can't keep the solenoid open causing the carb to shut off the fuel flow causing the unit to die. The easiest way to check if it works is by turning the key to the run position and listen and/or feel for the solenoid to click. If it clicks it is working and there is another problem, if it doesn't then replace it. I recommend having the battery tested or replaced too
Jan 03, 2013 | Garden
Jul 15, 2012 | Garden
My Yard Riding Lawn Mower won't start when I turn the key on it just clicks
Click means solenoid has enough battery power but maybe not enough battery power for the armature of the starter to spin, it may be low battery or bad solenoid contact - inside it, (copper washer and pin), or thirdly it may be the engine is stuck so try to turn it a bit by hand to rule this out. Turning the engine a bit by hand may also free a starter gear that has jammed on the flywheel teeth.
Jun 30, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Apr 04, 2012 | Mtd Garden
Tecumseh 4.5 hp engine won't start
First thing to check on a Tecumseh; pull the half inch bowl nut (main jet) out of the bottom of the carburetor. Give it a good cleaning with carb cleaner then pay special attention to the teeny tiny hole that is right at the very top of the threads. It's so small you can hardly see it and if it clogs, your mower won't start. Best of luck to you.
Oct 29, 2011 | Mtd 22" Yard Machine Push Mower
Garden Logo
166 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
