Question about Garden
14.5 hp mtd riding mower won't turn over
My 14.5 hp mtd mower died and it won't turn over. I replaced solenoid cause someone said if I made contact with both post on solenoid and it turned over that it was a bad solenoid. Not true in this case. Someone bypassed the seat safety switch. Wires are hanging and looks like something is missing in area next to solenoid. This hasn't kept it from starting before.What else can I look for?
  • 376 Answers
SOURCE: Poulan Riding Mower won't crank, battery OK.
Forget the safety switches for now.The first thing I would check would be the fuse. It will be located on the battery side of the solenoid. Follow your positive battery cable to the solenoid. There will be a small red wire coming off of that post with an inline fuse. If the fuse is good, check your solenoid. There are two wires plugged into spade terminals at the bottom of the solenoid. Unplug the one that is insulated, the other one is a ground. Hook a test light from that wire to ground. When you turn the key to start (with the brake pedal held down), it should light. If it lights, your solenoid is bad. If not, then you can start looking at switches. Probably will be one of the two. Hope this helps. Dwain
Posted on May 21, 2009
  • 106 Answers
SOURCE: My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Posted on Jun 04, 2009
al_kupchella
  • 843 Answers
SOURCE: How do I bypass my seat safety switch on my
It's not a good idea. But if you must, it's just a switch. If it has two wires, cut them from the switch and connect them together with a wire nut. If it has only one wire, then cut it from the switch, put a spade terminal on it, and connect it to the frame of the tractor.
Posted on Jun 29, 2010
  • 3 Answers
SOURCE: Mower starts, but when I let off clutch, it dies.
when the seat goes out of adjustment due to the crappy adjustment bolt design, the bolt inadvertantly engages the safety switch under the seat.
Posted on Oct 24, 2010
SOURCE: MTD RIDE ON LAWN MOWER SOLENOID
CHANGE DRIVE BELTS
Posted on Nov 09, 2010
How do you find an inline fuse for a mtd riding mower 38 inch cut 14 horsepower
Start at the ignition switch and look for the starter wire..it should be the one tat is slightly heavier and normally red..and goes to the solenoid pos side..good lu k
Nov 16, 2014 | Mtd Garden
14.5 HP MTD MOWER WON'T TURN OVER
Can you turn the motor over by hand? Make sure it's free and can turn. Is starter drive engaging into flywheel. If mower was run with low oil or on a slope it may have seized up.
Jul 25, 2013 | Mtd Garden
Cub Cadet Riding Mower LT 1046 have to jump, but won't stay running
Check the bottom of the carburetor for a little solenoid. If it has one, the battery may be dead enough that it can't keep the solenoid open causing the carb to shut off the fuel flow causing the unit to die. The easiest way to check if it works is by turning the key to the run position and listen and/or feel for the solenoid to click. If it clicks it is working and there is another problem, if it doesn't then replace it. I recommend having the battery tested or replaced too
Jan 03, 2013 | Garden
MTD Ranch King Mower won't start
check the safety switches bypass them with a paper clip to test them
Jul 15, 2012 | Garden
Dynamark riding lawn mower won't start, new battery but will not turn over?
use jumper cable to test the starter if ok jump the small wire at the solenoid to power and see if it kicks it over if yes check the safety switches
May 13, 2012 | Garden
I have an MTD Rider with 18hp Briggs that stops running after about 20 minutes. Last time it died I turned the key and nothing happened. I have replaced coil, silonoid and key switch still nothing. I...
if you need to jump the solenoid to start it and it shuts down sounds to me that you have a bad safety switch start with the one on the pedal
Apr 29, 2012 | Mtd Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
