Question about Frigidaire FGF368GC Stainless Steel Range
Frigidaire GAS range
Control panel for oven stopped working. Checked outlets. They are fine. No power at all. Can't turn on oven, set temp, time or clock. We did have storms in the area today.
  • Official Brand Answer
  • 4,342 Answers
Hi Jo, thank you for your question! Let's try resetting the appliance by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back. If resetting the power does not correct the issue, your range could possibly have a faulty EOC (electronic oven control) or a potential wiring failure. I would suggest contacting an experienced service technician to determine the precise cause to reduce the risk of unnecessary parts.
Posted on Jul 25, 2013
IFIXALL
  • 868 Answers
SOURCE: Electronic Oven Control won't work after power failure
Replace the clock.
Posted on May 22, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
  • 119 Answers
SOURCE: Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Posted on Jan 14, 2010
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
Posted on Mar 22, 2010
I hit bake & it says off. I can't get the oven 2 say anything but off. Usually I hit "bake" & then up arrow 2 set temp but now as soon as I hit 'bake' or anything else it says '
Power reset it from the circuit breaker and if this does not help the control panel become more adverse to your selecting, then contact a professional. Sounds like the control board is going out.
Dec 28, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My Frigidaire FEFL77ABF range oven gets too hot. When set for 350, it goes to 450. High temp isn't consistent, so I can't adjust for it. Have cleaned oven and tried reset procedure - neither...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
When the oven is turned on about 10 minutes later a f10 code comes on with a beeping. I've tried upluging from the outlet waiting 1 min. before reappling the power cord. I still get a f10 code
The F10 error code indicates a runaway temperature condition. If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor & control checked.
Jan 22, 2011 | Frigidaire Gallery GLEFZ384GC Kitchen...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire gas range oven won't work
Hello Welcome,
If you get a F1 this means Circuit board is defective.
And you need to Check or replace: the control board.
This is a job for service to be sure before you buy the control board!
Thank You Huuum.
Please remember to leave a solved rating before you sign off!
May 21, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
Oven won't heat up to set temperature
IF THIS IS A GAS RANGE, AND IS USED ALOT, 4YEARS IS ABOUT THE LIFE EXPECTANCY OF THE IGNITOR FOR THE OVEN. IF THE IGNITOR IS WEAK, IT MAY NOT OPEN THE SAFETY VALVE. WITH A FLAT IGNITOR, IT REQUIRES 3.3AMPS TO OPEN THE VALVE. IF IT IS A ROUND IGNITOR, IT REQUIRES 2.8 AMPS TO OPEN THE OVEN IGNITOR.
IF THIS IS AN ELECTRIC OVEN WITH AN ELECTRONIC CONTROL, I WOULD SUSPECT THE OVEN SENSOR AS THE DEFECTIVE PART. AT ROOM TEMP, IT SHOULD READ ABOUT 1084 OHMS OF RESISTANCE.
IF IT IS A MECHANICAL CONTROL(WITH A KNOB) IT MAY BE ADJUSTABLE BY REMOVING THE KNOB AND INSERTING A THIN SCREWDRIVER UP THE SHAFT OF THE CONTROL AND TURNING A SCREW IN THE SHAFT TO CALIBRATE THE TEMP.
Apr 04, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Slow heating and control panel clicking
I have a similar problem with my Frigidaire FAM156R1A Air conditioner. The unit is stuck on a temp setting and occasionally makes a beeping sound. Repair tech came out and told me the control panel was broken and that this is a common problem. I wrote more detail here: http://www.epinions.com/content_404700761732
Sep 23, 2007 | Frigidaire PLCF489AC Dual Fuel (Electric...
Frigidaire FGF368GC  Stainless Steel Range Logo
106 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
