Question about Astar Magnavox 19MD358B 19 in. LCD TV
Magnavox manual sound is clear, but has black screen
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
Sep 22, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Philips Magnavox 36" @10yr old has perfect sound and black screen
checked the vedeo section of the main PCB of the unit, maybe some defective parts, try to look the back of the picture tube if theres a light, if none, cheke also the horizontal section, especially the flyback transformer
Jul 31, 2009 | Philips Magnavox TS3260C 32" TV
Black screen and no sound
I had the exact same problem with my Magnavox TV. No sound and no video but the power light was lit. I finaly gave up on finding a solution on the web and called in a repair tech. He fixed my TV in less than 30 minutes. You can find the solution here.
http://www.magnavoxhelp.com
Jun 16, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 81 cm LCD TV Model No. MLCD32
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Jun 04, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
My Philips Magnavox 9P5511C102 color is faded and not clear. The colors seem faded (off) tv is not clear, like is got static, and picture is shaky. I have tried to fix using the Main Menu already. Out of...
update the firmware/software if possible. my 60" has a USB slot on the right side. also you can download the manual from phillips http://www.support.philips.com/support/html/index_us_en.html#../~scripts/xsltransform.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=us_en||mode=cats||item=TV_GR&xsl=subcatalog.xsl
my phillips 60PP9200D/37
Apr 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
Screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
Astar Magnavox 19MD358B 19 in. LCD TV Logo
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
