Jvc tv I replaced the projection lamp and my picture is dark and takes 2 or 3 hrs. to warm up.It won't get bright like it use too.??
    Top Expert:
  • 12,223 Answers
FOLLOW this steps and fix it. God bless you
  • 1
    Power down the TV. Let it cool down for several minutes to avoid touching anything hot. There are many parts inside the TV that could be hot.
  • 2
    Unplug the TV and all media devices attached to it. Let the TV sit again for several more minutes just to be safe. The lamp receptacle and other components could still be hot.
  • 3
    Unscrew the back cover of your TV with a screwdriver. Have someone help if the cover is big. The lamp's housing unit on most TVs is located towards the bottom. Refer to your TV Owner's Manual for specific instructions.
  • 4
    Unscrew the lamp's housing unit with your screwdriver. Take your time to avoid damaging the housing unit. You'll see the lamp once you open the housing unit.
  • 5
    Use a soft cloth to unscrew the lamp out of the housing unit. There's a possibility the lamps- could still be hot. The cloth will help protect your hand.
  • 6
    Screw the replacement lamp into the housing unit with the same soft cloth. The oils from your fingers could ruin a rear projection TV bulb.
  • 7
    Reattach the lamp's housing unit and TV back cover. Make sure no wires are loose or get caught when screwing the back cover on.
  • 8
    Attach all media devices like cable or satellite boxes. You should now be able to watch your TV with a brand new picture.
Posted on Jul 25, 2013
TVtechmaniac
  • 140 Answers
SOURCE: The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Posted on Aug 30, 2007
  • 1694 Answers
SOURCE: screen too dark even with all brightness settings set to max
Try turning up screen voltage with control on transformer....
one is for more brightness and one is for focus.......T.
Posted on Dec 11, 2007
  • 149 Answers
SOURCE: dark picture on toshiba tv 32af44
Sound like the back light has gone, its what gives the picture brightness. Sounds like a technician job. Sorry........
Posted on Apr 10, 2008
JollyRoger00
  • 59 Answers
SOURCE: Hi. I have a JVC tv model AV27430, and the picture
What he was refering to is called the "FLYBACK"
It is a voltage regulation circuit that has 2 controls, 1 for brightness or "GAMMA" and one for focus.
WARNING:: TV'S HAVE HIGH VOLTAGE THAT CAN KILL YOU
To locate your flyback simply remove the back from your tv and look at the main tube, off the main tube will be a cord that looks like it comes from the top inside of the tube and goes down to a circuit board, that is the flyback, and if you look on it it should have 2 turn knobs or potentiometers , some manufactures glue these in place but the glue is easily removed. 1 of the 2 is the brightness, it's eisier to put a mirror up so you can see what your doing other than ask someone to tell you.
This is a picture of a flyback outside of the TV
http://www.fixya.com/uploads/images/767D93D.jpg
Posted on Sep 23, 2009
SD Tech
  • 14553 Answers
SOURCE: jvc av-27432, the picture on this tv is very dark.
There is a way to adjust this but it requires removal of the entire back cover-----YOU HAVE TO BE VERY CAREFUL WHEN YOU DO THIS AS THE SET HAS TO BE HOOKED UP AND TURNED ON!
IF the problem occurred over a period of time you have a good chance-----if it happened suddenly--you have a problem in the set.
With the back removed locate the HIGH VOLTAGE TRANSFORMER- it will have a large red wire coming out of the top of it that snaps into the top center of the picture tube (this is the anode lead) DO NOT GET ANYWHERE NEAR THAT LEAD WITH THE SET TURNED ON---ABOUT 25 THOUSAND VOLTS IS THERE
IF YOU LOCATE THE TRANSFORMER(ABOUT THE SIZE OF YOUR FIST) IT WILL HAVE TWO CONTROLS ON THE BACK---the upper one is Focus and the lower is SCREEN
With the set on turn the lower control (Screen) slowly to the right until the brightness comes UP---DO NOT TURN TOO FAR OR YOU WILL GET TRACE LINES AND THEN THE SET WILL SHUT OFF!
If adjusting the master screen does not solve the problem---you have a circuit problem and the set may or may not be worth fixing. Usually if the picture got darker over a long period of time--just adjusting the screen control up A LITTLE will restore things to normal.
I cannot tell you how important it is not to touch anything in the set---keep one hand in your pocket and use the master screen slowly.
Let me know what happens and if you have any questions ask before you attempt this.
Regards, SD TECH
Posted on Oct 10, 2009
Picture it too dark cannot increase brightness
It could be your lamp. I'd bet that it's your problem. They only last for so many thousand hours. On many DLPs it's very easy to replace the lamp. There are many youtube videos on replacing the lamps if you need help.
May 04, 2012 | Pioneer PRO-620HD 58" Rear Projection...
I have a philips 60pl9200d/37 the picture is fairly dark even though I've turned the brightness all the way up
The lamp can cause a dark picture if it is defective. There is an access door to the lamp. Take the lamp out and inspect it. Especially at the bottom of the center stem where you may see a bubbling of the glass. If so it is bad for sure. Other problem could be in the main board. For good price on lamp with housing go to pureglare.com and enter the model number.
Oct 24, 2011 | Philips 60PP9202 60" Rear Projection...
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Jvc hd-61Z786 REAR PROJECTION TV . is dark. replaced the lamp. did not help much
all u have to do is to
Reset Picture and Sound Adjustments
1.Press the "Menu" button.
2. Press the "CH+" or "CH-" button to "Reset" listed on the display.
3. Press the "Volume+" or "Volume-" buttons to move left or right to enter your Reset selection. The Reset will reset all of your picture adjustments, including the color, brightness and tint to the default settings. Reset also resets your sound adjustments to the default settings, like the balance, bass and treble.
4. Press the "Menu" button to complete the resetting process
Feb 23, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
Have a jvc projection tv picture is to dark how can i correct this
How long is ur tv projection lamp been inside this tv.If the tv projection lamp been inside the tv like 1 1/2 or 2 years and watches tv everyday like 4 or 5 hours daily.The tv projection lamp life are ending.Replacement of the tv projection lamp,will solved this problems.
Dec 28, 2010 | JVC HD-61Z786 61" Rear Projection HDTV
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I have a Samsung HLR5656 model and the picture is now very dark even DVD are dark. Still watchable but it looks like everything is shot at night time.
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9600826A You can find it here:http://www.discount-merchant.com/Samsung-BP96-00826A-Lamp-Enclosure-p/samsung-bp96-00826a-lamp-enc.htm?Click=48173. Have a blessed one!
Apr 19, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Ihave a Philips 50PL9126D tv and I just replaced the lamp because the picture was very dark. I can see the picture but it is still somewhat dark, bright in the middle,dark at the edges. I tried to adjust...
Sounds like you may have the wrong lamp. Make sure you purchased a Philips lamp that's 100% compatible with your television model. Philips pioneered that lamp, so naturally they make 100 different types for DLPs and LCD projections.
You may have an elliptical lamp instead of parabolic. The lamp for your TV should read P22h.
Feb 04, 2010 | Philips Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
