Question about Denso Computers & Internet
Denso cu311 information about cu311 cradle/
Tip
TOYOTA GAS PEDALS, and related information
Hello again, I am the resident Toyota expert here at FixYa.
I work for a Toyota dealership, and, with this tip, I hope to shed some light on the alleged Toyota gas pedal issue, and bring some comfort to all of the Toyota owners that read this.
If this tip helps you, please click on the "helped" icon below. Thanks.
The first thing owners need to know is this:
There are TWO different manufactures of the gas pedals that Toyota uses in their cars. They are as follows:
C.T.S. and DENSO
The CTS pedal is the one currently being modified at your local Toyota dealerships. The government (specifically, NHTSA, has inspected and approved the ongoing repairs, take comfort that the government is very aware of the repair, and is in agreement with Toyota that this modification will cure any possibility of the accelerators 'stciking'.
Now, The DENSO pedal is markedly different, and has been found to have NO ISSUES of the alleged sticking condition.
Next, we need to address exactly WHICH cars have the allegedly affected gas pedal installed.
Look at your 17 digit Vehicle Identification number...If it starts with a ' J ', this denotes that you have a Japanese produced vehicle, and ALL Japanese produced vehicles will have the DENSO pedal fitted.
Again, the DENSO pedal has been shown to have no sticking issues.
If your car/truck has a 1, a 2, a 4 or a 5 in the first position of the VIN, this indicates that your vehicle is American production. If you have an American production vehicle, don't panic.
The CTS pedal is installed in about 50% of the American production vehicles. American production ALSO has the DENSO pedal fitted.
You can easily check to see which pedal you have, by looking at the black box that is connected to the moving part of the gas pedal. This is ABOVE the part where you press on with your foot
With a flashlight, illuminate the gas pedal in your car. If you cannot see a shiny silver metal plate on the side of the pedal box, that faces the brake pedal, you have a DENSO pedal. Look closer, and you will see the DENSO word visible on the side of the pedal assembly.
Again, DENSO pedals are not involved in the alleged 'sticky pedal issue'
The CTS pedal has a shiny silver metal plate on the side of the pedal, that faces the brake pedal. If you can see this shiny silver metal plate, you have the CTS pedal, and will need to take it to your Toyota service department, and they will modify the pedal. This procedure will take about 45 minutes.
Vehicles involved in the current CTS pedal modification:
Avalon
Camry
Corolla
Highlander
Tundra
Sequoia
Matrix
Vehicles NOT involved in the CTS pedal modification"
All Japanese production, AND
Yaris
FJ Cruiser
All SCION
Venza
Solara
Sienna
So, to sum up this tip...If you have a CTS pedal, it needs to be modified. As of this writing, I have personally modified over 150 pedals, and have YET to see one that was remotely sticky. Rest assured that the modification that your Toyota service department will eliminate any worries that you may have with regard to your gas pedal.
Hopefully, with this Tip, I have provided you some useful information, and, with this info, you will be able to know which pedal you have, and, if you DO have the CTS pedal, please make an appointment with your local Toyota dealership for the modification. ALl of the Toyota dealers have sufficient quantities of the repair parts on hand.
If you consider this tip helpful, please click on the helpful icon located below. If you want or need any more information, please feel free to post up a question in the question area located on this site, Preface your question with the following: "A Question for TOYOTA ED,,,,",
I will get right back to you.
Thanks for reading my tip.
Toyota Ed
2-14-09
on Feb 07, 2010 | Toyota Camry Cars & Trucks
What spark plugs are cross refrence for a champion plug RN4C
Oct 12, 2014 | Champion International Champion& Small...
Toyota Denso Intelligent Tester II Toyota IT2 support all toyota?
Contact the manufacturer on this, we do not have this information.
Aug 24, 2012 | Toyota Toyota Cars & Trucks
I got a code P1150 only 2000 Sienna LE, which I guess means Bank 2 Sensor 1. I am looking at Denso replacement part. It has upstream left (234-9007) and upstream right (234-9009). Is bank 2 sensor 1,...
Ravi, I also have the same issue and confused between upstream left and right location.
I have problem with bank 2 sensor 1 and want to purchase a part. There are two part numbers 234-9007 for upstream left and 234-9009 for right.
So not sure the one on radiator (bank 2 sensor 1) side is upstream left or upstream right.
If you already know can you please reply?
Apr 10, 2012 | Toyota Sienna Cars & Trucks
Scandisk found invalid files refer to file "$$BRKLST.SYS" for more information. refer to system administator error (3010)
Scandisk found invalid files refer to file "$$BRKLST.SYS" for more information. what can i do to resolve this problem?
Aug 05, 2010 | Denso BHT-8044D
Where is my barcode after I scan it?
Is the cradle connected to the pc via either usb, serial or keyboard wedge?
If so you will need to first, pair the scanner with the cradle by scanning the barcode on the cradle and second, configure the cradle properly so it transmits the data to the host.
Download the product reference guide from motorola website. You will get all the configuration information you need in there.
Mar 20, 2009 | Symbol LS3578-FZ Barcode Scanner - P/N...
Static electric discharge - IBM WorkPad c500, c505 (8602-60x / 70x) 2003-08-04
Palm Inc., the manufacturer of the IBM WorkPad, has recently informed IBM that a limited number of IBM WorkPad c500 and c505 models may be unable to use the HotSync function if a static electric discharge (ESD) takes place when the WorkPad is placed in the cradle. Palm Inc. has designed a new cradle for this condition. It has the Palm Inc. logo on it, but also works with these WorkPad models. Palm Inc. has a Web site that provides more information on this issue and also contains the Palm Cradle Exchange Program, which allows owners of eligible models to receive a new cradle. To determine if your WorkPad is eligible and to place an order for a replacement cradle, please visit the Palm Inc. Web site. NOTE: If you are in the Asia Pacific region, please contact the Palm Customer Information Centre in your country for information on how to recieve your replacement cradle. Links to this support information can be found at http://www.palm.com/asia/support/contact/asiapacificsupport.html NOTE: When ordering a replacement cradle from Palm, the entire IBM WorkPad serial number (16 digits) must be entered. The format is 1S8602MMMxxxxxxx (Where MMM is the 3 digit model number and xxxxxxx is the unique serial number).
Sep 14, 2005 | IBM WorkPad c500
Computers & Internet Logo
22 people viewed this question
Top Denso Computers & Internet Experts
David Payne
David Payne
Are you a Denso Computer and Internet Expert? Answer questions, earn points and help others
