Question about DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale
HHH Error code HHH meaning and how do I fix ?
My digi 100×0.01g reads HHH HOW DO I FIX
That means it is sensing something heavy that is not present. HHH means high limit reached. It is either dirty or has a problem with a sensor
Jun 20, 2016 | Kitchen Appliances - Others
Sw13 scale reads HHH
Most likely HHH represents an error message telling you the weight of them item is higher than the scale can handle. For example if you had a very sensitive scale that weighed up to 50 carats and you put a 250 carats ring on the scale, it would give you an over load error message.
May 17, 2014 | NATASHA COLLIS Gold nugget ring with mixed...
HHH shows in the window. Won't start. What is the problem
The error code for HHH usually means it is too hot, if it is has been used recently. If it has, unplug the machine, and try to wait for it to cool down with the lid open for about 15-20 minutes. If that is not the case, I would suggest you to contact the manufacturer at:
https://secure.sunbeam.ca/ContactUs.aspx
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Sunbeam 5891 Bread Maker
What does HHH mean on the breadmaker 2250??
HHH on your breadmaker means the units it too hot to begin a new batch. Stop the machine, take out the bread pan and allow the unit to cool with the cover open.
Sep 29, 2010 | Black & Decker Bread Machine
What does code HHH mean?
That's a troubleshooting code listed in the manual. It means something is broken and you should take it to a service center for repair.
Dec 06, 2009 | Cuisinart CBK-200 Bread Maker
HHH Error Code
Generally, an HHH error code means the machine is sitll too hot from making the previous loaf. Keep the door open for a bit and allow it to cool down.
Dec 25, 2008 | Sunbeam 5891 Bread Maker
The Cuisinart CBK-200C stopped in the middle of a dough cycle
Please check your shaft and bushing on the bottom of your bread pan . What is happening is the bushing is dirty and binding , your drive motor is heating and resetting or stopping , I just fixed this by pulling out the shaft and lubricating it with loive oil . It works so good now , better than new !
Jul 22, 2007 | Cuisinart CBK-200 Bread Maker
DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale Logo
65 people viewed this question
Top DigiWeigh Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a DigiWeigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
