Question about Sanyo DP46848 LCD TV
Loss of Picture
Started with a band appearing across top of picture now picture almost completely white with ghost like images. very faint flashes of washed out color. Sound OK
    Top Expert:
  • Sanyo Master
  • 74,482 Answers
It sounds that the CCFL lamp has the fault. Contact any service technician to make it confirm.
Posted on Jul 25, 2013
3 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: The model is Sanyo LCD-37XR9DA.
You have a malfunctioning main a/v board. This problem is caused due to malfunctioning video processing circuit. Replacing the main A/V board should resolve your problem. Let me know if you wish to do it yourself so that I can find you a replacement
Posted on Jan 24, 2011
  • 8457 Answers
SOURCE: The picture bleeds down to a black screen. At
Ur main backlight video board is the cause,must replaced.
Posted on Nov 18, 2009
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
I have the Phaser 6200 and ghosting images are starting to appear on everything. I would say that about one third of the top part of the page is being reprinted very faintly at the bottom of the page. ...
Most likely you need to replace the fuser. The teflon coating on the heat roll wears, when it does some of the ink sticks to the roller and winds up as a "ghost" image across the page.
It could be your imaging unit. But more likely is the fuser.
Let me know please.
Jul 23, 2008 | Xerox Office Equipment & Supplies
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
White bands appearing across pictures
Mikrofiber towel and a few drops of wather.
Clean the lense even if looks clean.
Try to reset the camera in the menu to the factory settings.
If not help service only.
Nov 11, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Sanyo DP46848 LCD TV Logo
148 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
