My zoostorm laptop beep when turns on and then turn off
It let me enter password then it shut down like its out of charge but it says its fully charged any help would be appreciated
SOURCE: Toshiba Satellite M65-S909 laptop will not start
I had the same thing happen when I was fiddling with the 9092 monitor refresh rate. The video circuit had a few episodes of video switching and the system shut down never to wake again. I figured it was connected to this circuit but I couldn't fix it. I bought a new one but I haven't tried to recreate the problem:-|
Posted on Aug 30, 2008
  • 5 Answers
SOURCE: Battery Problem
you should tae your battery to a mechanic it may be a capcitor problem or may be a cells problem which are present in battteries
Posted on Sep 25, 2009
Geekman
  • 32281 Answers
SOURCE: Laptop turns off intantly, when I unplug the charging cord
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
The laptop's charging circuit maybe faulty.
Posted on Nov 26, 2009
For those of you having the problem of a HP laptop shutting off when you unplug the charger and your battery is fully charged, I can help you. There is nothing wrong with the laptop, battery, or computer, it is a power management setting. If you go to display properties, select the screen saver tab, then click the "power" button, in the power schemes field is a drop down window, click on it and select "Rixane Power Scheme", it is a power switching utility that quickly switches between AC and Battery when the power cable/charger is plugged in or unplugged while the laptop is on. If you have it set to "always on" it will shut off when you pull the power cord, even if the battery is charged. This will also happen on many non-HP laptops, if you don't have a HP laptop or there is not a "Rixane" option available, select the "Portable/Laptop" power scheme. Hope this helps!
Posted on Feb 20, 2010
SOURCE: Lenovo g550 turns off when power supply is disconnected ,battery shows fully charged
Replace the battery, it's faulty.
Batteries only have a useful life, then they have to be replaced. Sounds like yours is doing like the ink cartridges, where they register as being full of ink when actually there is no ink in the cartridge.
Posted on May 19, 2012
Testimonial: "Yes. Replaced battery and it works fine. Thanks"
Model PL81. Why does it zoom, beep, and shut down?
Are you positive that the battery is good? Turning on for a few seconds and then shutting down is a classic symptom of a battery that did not take a proper charge and as soon as the surface charge is used, unit will shut down. And what if your charger is not properly charging the battery?
If you have a battery eliminator try that in lieu of the battery to see what happens.
Mar 28, 2016 | Samsung Cameras
My Gateway laptop, NE56R1u, shuts down automatically when unplugged even though fully charged?
Dear Leslie,
I had the very same problem with a HP Pavillion DV4 laptop and the problem was inside the battery - one of its cells became defective and the charge did not last more than a few seconds - it also showed a 100% charged icon but the battery was depleted in seconds.
Before buying a brand new battery you could check with a friend that has a similar laptop if he/she can lend you his/her battery for a few minutes and check whether the laptop keeps on or not with that other battery. In the case it remains on, it is the battery for sure, and you will need to buy a replacement one. Check the link below, for one option.
Hope you may find this information useful!
Best regards,
Miguel L. Martins
6cell Laptop Battery for Gateway NE56R41u NE56R42u NE56R43u Nv50A02U...
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
Gateway laptop shuts down instantly when unplugged but fully charged.
I have come across connection issues on the battery terminals. Make sure the brass contacts are not tarnished or bent. Have you tried another battery?
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Sep 25, 2013 | Gateway Computers & Internet
Beeping laptop
I had the same thing happen to me on a fijitsu siemens amilo pro and i found the problem to be with the memory changed one module and it helped try this and i hope it helps.
E.F.Barnes
Jul 27, 2013 | Computers & Internet
How to disable drivelock password
The Compaq drivelock feature is designed to protect the data on a laptop's hard drive by assigning a password.
This password protects the drive in the event the laptop is lost or stolen, but can be removed when necessary.
Knowing how to remove or change the drivelock feature can make your Compaq more useful and more secure.
Power on your laptop and enter the drivelock password you established when you turned the drive protection feature on.
You will need this password to access the drive and turn off the drivelock feature.
Click the "Disabled" option in the drivelock menu.
This will turn off the drivelock feature on the Compaq laptop.
Do not enter anything in the password blocks.
Log on to the laptop, click the "Start" button and choose "Shut down." Choose "Restart" from the menu to power cycle your laptop and verify the drivelock setting is off.
If the drivelock setting is off you will not be prompted for a password when the laptop starts up.
hope this helps
Oct 19, 2012 | Compaq Presario 2140US Notebook
Water damaged Laptop
Attaching an external keyboard does not help because the keyboard controller is damaged.
I recommend you put your money towards a new laptop as the cost of repair maybe too expensive or beyond repair. Most computer repair shop charge for a quote and may drop this charge if you go ahead with the repair.
If the hard disk is OK then I suggest you remove it from the laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive for backups and data transfer etc.
Mar 04, 2012 | Toshiba Satellite C650 series C655S9520D
When i turn the power on after two minutes it shuts down right away. tried to charge it still the same it will turn on for 2 mins then shut down again. i tried rebooting it press f8 but it gave me another...
you got 2 things here:
1. pc shutting down unexpectedly
2. blue screen
1. the cause could vary:
a. cpu overheating: make sure you are letting the laptop to breath, open/clean vents.
b. motherboard failure: get a new laptop.
c. battery failure: try to take the battery out and connect the laptop and test/replace the battery as needed.
2. blue screen: if it is a Blue Screen of Dead, try to note any error codes and post back or at this stage it could be virus: take the hd out, connect it to an enclusure and hook it up to another good computer and attempt to save the usuful data. then reinstalled hard drive in laptop and reinstall os.
b. hadware failure: replace laptop.
on the password:
the only three possibilities where you may be asked for a password is if you're trying to access a password protected bios (which you rarely do with f8) or if you're accessing the recovery console in which you need to enter your windows user name and password or if you're accessing the computer in safemode in which you can enter any user name and their password or the user name: Administrator and for password it could be either blank or whatever password was set when windows was installed
good luck!
Mar 19, 2010 | Toshiba Qosmio F45-AV412 Notebook
My 580 phone is fully charged has been turning off by itself, it beeps then shuts down,i do charge the phone when battery is low
how old is battery ? rechargable battries can get a memory to them if very old get a new battry
Feb 02, 2010 | Cell Phones
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
