MXL 990 Professional Microphone Logo
Anonymous Posted on Jul 24, 2013
Repair how can i fix the inside part of my mxl 990? it came loose some how. it's the part that picks up the sound itself. can i take the screem off so i can screw it back on so it's not loose?
Greg Y
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Jan 24, 2015
Greg Y
Contributor
Level 1:
New Friend:
Answers
41
Questions
Helped
9994
Points
69
If you are good at doing such things yes, but the parts inside are very delicate and must be handled gently as not to damage them. If you are not comfortable doing it then I would suggest taking it to a local music store where similar items are sold to see if they can do it for you.
5 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Sep 11, 2008
SOURCE: Problems with my MXL 990 (radio)
g'day mate.
The problem you have will relate to the big antennas in your area. Most radio stations pump more than 100,000 watts these days. So it really comes down to the shielding and what's called Radio Frequency Interference rejection of your microphones to keep this out. I would STRONGLY urge you to take the mics back and get a refund,or change them over for something else. They are VERY cheap, there is no real solution to your problem, except for better design... means spend more mullah. If you are looking for a decent low cost condenser mic, I recommend an AKG Perception. I have used AKG for years, and this mic is a great sounding low cost unit.
Hope this helps you. Nothing can be done to improve what you have, they are a cheapo item. Good Luck
regards
robotek
Anonymous
  • Posted on Feb 28, 2009
SOURCE: Can't operate my MXL 990
If it is an MXL 990 Condenser that comes in the grey case with a shockmount and a black hard mount I can solve your problem. (If it is USB I know nothing about that unit).
This MXL 990 microphone MUST have 48v phantom power in order to operate. If you aren't familiar with the term phantom power read the first link:
Phantom power - http://en.wikipedia.org/wiki/Phantom_power
MXL User Guide - http://www.mxlmics.com/support/guides.html
If yours is one of the older MXL 990's it should have an XLR connector on the bottom -
XLR Defined - http://en.wikipedia.org/wiki/XLR_connector
Your mixer (I am guessing its a Peavey, Tascam, Mackie) or something entry level like that may or may not have phantom power. I am guessing not. But if it does, it will have a switch that says 48v phantom power and most likely a green or red LED next to it to show you when its on. This mic will NOT work without phantom power.
Best suggestion: Verify that your mic is the MXL 990 Condenser, if it is it needs 48v phantom power. Check your mixer and see if it has 48v phantom power. The only computer soundcard that I know of that is used by a lot of folks is the M-Audio Delta 1010LT. It has XLR inputs but NO phantom power on it.
There's your answer.
Ray
Anonymous
Luis
I guarantee you the antennas are most likely the culprit. Your only solution is to have a tech check the unit, OR purchase an inline RF filter from Radio Shack. It is also possible that you have a capacitor or other component going bad, that is causing the unit to heterodyne and become a nice front end for a radio receiver.
You do have other microphones, and they do not do this. Averages says it is most likely the microphone has an issue or its design. I have one of these MXL 990s too, and my mic began motorboating a few months ago while I was trying to record with it. It may be a quality issue with these mics. They aren't complicated though, any component electronic tech should be able to check it out.
Szieve
  • 11 Answers
  • Posted on Aug 10, 2010
SOURCE: how do i hook up a mxl 990 microphone to my
Get an audio interface. usb or preferably firewire if your computer supports it. I'm assuming that you do not have the usb model. this mic requires phantom power to operate, so the audio interface should be capable of producing that. You should be able to get one from your local music store (guitar center)
Anonymous
  • 5807 Answers
  • Posted on Sep 30, 2012
SOURCE: i got a cable to hook my MXL 990 condenser
hi
mousewalk20
what you may need is one like these:
X2u XLR to USB Signal Adapter
http://www.shure.com/americas/products/accessories/microphone-accessories/problem-solvers/x2u-xlr-to-usb-signal-adapter
990 mxl condenser mic rattles
Not supposed to rattle. Sounds like it may have been dropped. Very delicate parts inside these comdenser mics. Even blowing into them can damage them. Maybe you could get luck to find a screw that vibrated lose if you carefully disassemble the unit. Or you can take it to your local music store/ electronics repair shop and have them repair it.
Is the 990 an externally polarized capsule or electret?
The MXL 990 is an externally polarized condenser microphone. You will nee to provide 48v Phantom power to use it. Alternatively there is a USB version, the MXL 990 USB which gets it['s power from the USB port.
I've tried several mics: mxl 990, Sure sm58/57, an AKG mic, and I get very low input signal or no signal at all from the mxl 990. The problem is the same regardless of phantom power. Cranking the input...
1. maybe the impedance of you mic did not match to your sound card..
2. sound card did not support you dynamic mic...try to use FET or condenser mic..
I have a MXL 990 studio mic which I recorded one no longerworks
Are you using the original cable for the mike? In order to use phantom power the XLR connectors have to be wired in balanced configuration. Pins 1,2 and 3 must be wired separately. If you use a cable with 1and 3 connected you could damage the phantom power supply and in some cases the microphone.
1helpful
I bought a MXL 990 USB, and I cannot connect it to my PC. I followed all the instructions, but couldn't get a sound from it. Can somebody help me? I have Windows Vista
Make sure you've switched your sound input from the default (internal mic/input) to the MXL 990. This should be somewhere in the sound options.
If you're sure it's not getting power, you need to send it back.
6helpful
3answers
Ray
2answers
MXL 990 doesn't work
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
3answers
Sounds like the frame of the microphone itself has become ungrounded. You could try VERY
carefully disassemble the mic and check for a bad ground or a bad wire connecting to the mic
body.
2answers
g'day mate.
regards
robotek
Top MXL Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a MXL Audio Player and Recorder Expert? Answer questions, earn points and help others
