Question about Dryers
360 rotation has stop working
Light works blakes turn but will not rotate
    Genius:
  • 1,617 Answers
What is the make/model of fan?
Posted on Jul 25, 2013
2 Suggested Answers
wiringlunati
  • 576 Answers
SOURCE: Light works, fan doesn't. It rotates freely, but
Make sure the switch on the fan is set to high first. If it is, either check the voltage coming out of the remote box, or bypass the remote box to see if the controller went bad. Be careful and only check voltages on live circuits if you have the knowledge to do so safely. Disconnect the power before attempting to rewire anything.
Posted on Mar 21, 2010
My 9537 lights up and goes thru the numbers 0-360 but the antenna does not movmove
Has this installation previously worked or is this a new installation?
Sounds like it may be in the rotator itself.
Dec 28, 2014 | Channel Master CM 9537 Antenna Rotator...
Engine will not rotate a full 360 degrees, 1995 Toyota Celica
You have a valve hitting one or more pistons, and it is not a metallic noise it just stops rotating.
Jul 19, 2017 | Cars & Trucks
Need to set the timer properly. No instructions to follow. Want lights to come on at 6PM and off at 6AM. the timer has red and black pegs on the timer, HEL:P
Experiment with the timer.
Hook up the lights and timer. And read resource link below.
Put the trippers on the dial. Put red at 6pm and black at 6am.
Then manually rotate the dial two revolutions.
Turn the override knob to different setting, and then manually rotate the dial two revolutions.
Watch what the lights do as you rotate timer dial.
Then rotate dial two revolutions until current time lines up with stationary arrowhead located on inner dial.
The clock motor located inside timer rotates the dial, and trippers move small switch that turns lights on-and-off.
More resources with important tips for power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/How-to-set-timers.html
Sep 27, 2011 | Malibu ML88TL 88Watt Low Voltage Power...
Rotating dial no longer turns. lights come on ehrn rotated manually.
You posted under Malibu power packs:
Open following link for troubleshoot steps, manuals, warranty information:
If timer dial is no longer rotating, the clock motor is bad.
There are no replacement clock motors for Intermatic/ Malibu.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Work around problem: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Apr 16, 2011 | Malibu Hardware & Accessories
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
Karcher Dirtblaster jet does not rotate
Had the same problem and it turned out to be an obstruction in the nozzle and I mean a small obstruction, it looked like an ant leg. I pushed a 1mm drill bit through and now it works fine.
Apr 13, 2010 | Karcher K2.26 Electric Power Washer
Disk tray stops spinning disks
You need a new laser. Thats the only fix
May 28, 2009 | Microsoft Xbox 360 Console
Leapster 2 has no sound
We got our daughter a Leapster2 for Chrstmas 08. One day the sound just stopped working. Called Leapfrog. They said to insert a cartridge, and turn the unit on. Plug headphones into the headphone jack. Then rotate the headphone plug-in 360 degrees,( It is easier to hold the heaphone plug-in and rotate the leapster2). Unplug the headphones and check to see if the sound works. Leapfrog said try it more than once, and if it does not work contact them,1-800-701-5327. We tried it and Hallelujah it worked!
Feb 15, 2009 | Nintendo Game Boy Advance Console
Dryers Logo
87 people viewed this question
Top Dryers Experts
