Question about Car Audio & Video
How to reset jvc kd-rd411
Keeps saying protect pressed the reset button and after a couple of minutes goes off and says protect again
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
  • 136 Answers
SOURCE: set time onJVC KD-G510
hi sir, please try this: please go to the link below and then on the left side of the instructions please click the General Settings-PSM. it'll show you how to set the time. the manual will be helpful for you in the future so i suggest that u can save it.
http://dl.owneriq.net/d/dcf71de7-5dba-489d-b92e-6e935cc5644b.pdf
kindly rate me.. thanks for using fixya..
Posted on Feb 11, 2010
kenw392
  • 2226 Answers
SOURCE: My jvc car stereo says
try checking your speaker wires and speakers for shorts. if they check out fine, you may have a bad output ic inside the deck.
Posted on Aug 23, 2010
SOURCE: JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Posted on Feb 07, 2011
kenw392
  • 2226 Answers
SOURCE: jvc kd- r311 lights up
Check your speakers and speaker wires to make sure there are no shorts or grounds. If the speakers and speaker wires check out, you probably have a bad internal output ic.
Posted on May 10, 2011
How do you reset the jvc kd-s79bt?
Under the facia plate should be a reset button, use a paper clip or similar to press it in or disconnect the battery for a couple of minutes!
May 22, 2015 | JVC Car Audio & Video
How do I set the time clock on a JVC KD-S6060 ?
press the select button then scroll with the up and down button until h or m light up on screen then press vol button up and down to set or keep your finger on the sel button and adjust with left up down then press right up down to select hour or minutes
Aug 10, 2011 | JVC KD-S6060 CD Player
Jvc kd- r311 lights up and says PROTECT, thats it nothing else works. i have pressed the reset button loads of times and diconnected it and tryed again but nothing seems to make any difference. please...
May 10, 2011 | JVC AM FM CD DET FACE CAR STEREO
My jvc deck says PROTECT on it and won't let me listen to music or anything! What should I do?
my jvc kd-s37 keep going into protect mode now how can i get it where it stays out i reset it several time but it still goes back into it
Nov 25, 2010 | JVC AM FM CD DET FACE CAR STEREO
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC KD G-120 Clock Setting
once you press and hold select and get 'Area' release the select button and go ahead and press on the fast forward button until you you see clock H(hour), to set the hour turn the volume knob, then again press fast forward button to select clock M(minutes) and again use volume knob to adjust the minutes. once you are done make sure to press select to save setting.
Apr 09, 2009 | JVC KD-G120 CD Player
How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Apr 06, 2009 | JVC KD-G230 CD Player
How do I set the time on my JVC KD-G310
Push in the select button and hold it for 3 seconds. scroll through the list using your next button for the radio on the bottom right hand corner. once it says Clock H you can turn the volume knob to set the hour. hit the next button again and it should say Clock M for minute and use the knob again.
Oct 19, 2008 | JVC KD-G310 CD Player
Not reading MP3 cds
Have you tried removing the negative terminal from your car battery and giving it a few minutes. Hook the terminal back up and try your cd player again? That should be the same as resetting your cd player settings.
http://instrukcje.elektroda.net/caud/jvc/KD-G501.pdf
Sounds like you have a problem with the mp3 format being used.
Apr 19, 2008 | JVC KD-G501 CD Player
Jvc kd-g200 cd player
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=260a73e6d269444e666771376ad18c85&q=JVC+KD-G200
Type in the code shown at the bottom.
Click "download now"
Click where it says "link" in blue.
Click "save"
Save the pdf to your computer's hard drive.
Instructions are as follows:
Press and hold the "select" button for more than 2 seconds.
Press the "fast forward" icon button.
Turn the dial to appropriate hour.
Turn the dial to appropriate minutes.
Press the select button.
Apr 17, 2008 | JVC KD-G200 CD Player
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
