Question about Minka Aire F602-BNCH Gyro? Fan
360 rotation stop rotating
    Genius:
  • Minka Master
  • 1,617 Answers
Call 1-800-307-3267 Minka aire. I think you need a new receiver.
Posted on Jul 25, 2013
2003 Honda Accord engine code p2646 engine will not rotate 360 but stops.when turned in reverse by hand starter will turn then get stuck and will not turn forward. What is possible causes? Locked?
code p 2646 refers to rocker arm actuator A bank 1---performance problem or actuator stuck off=== causes wiring--- rocker arm actuator
discuss the problem with a service dealer shop or an accredited service shop that has experience on your make of vehicle
with rocker arm problems , to stop rotation it may be bottoming out on a valve spring and not letting the cam shaft turn .
talk with a shop for a proper diagnosis and quote
Dec 22, 2016 | Honda Cars & Trucks
My 9537 lights up and goes thru the numbers 0-360 but the antenna does not movmove
Has this installation previously worked or is this a new installation?
Sounds like it may be in the rotator itself.
Dec 28, 2014 | Channel Master CM 9537 Antenna Rotator...
Engine will not rotate a full 360 degrees, 1995 Toyota Celica
You have a valve hitting one or more pistons, and it is not a metallic noise it just stops rotating.
Jul 19, 2017 | Cars & Trucks
360 rotation has stop working
What is the make/model of fan?
Jul 24, 2013 | Dryers
88 ford f 150 - where can i find the spark plug wiring diagram- I have the book but it doesn't mention it. And what is the firing order
300 straight six 153624 distributor rotation clockwise, 232 v6 142536 distributor rotation counterclockwise.
255/302/360/390/460 15426378 distributor rotation counterclockwise,
351 & 400 W & M 13726548 distributor rotation counterclockwise.
Jan 14, 2011 | 1988 Ford F 150
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
Karcher Dirtblaster jet does not rotate
Had the same problem and it turned out to be an obstruction in the nozzle and I mean a small obstruction, it looked like an ant leg. I pushed a 1mm drill bit through and now it works fine.
Apr 13, 2010 | Karcher K2.26 Electric Power Washer
Disk tray stops spinning disks
You need a new laser. Thats the only fix
May 28, 2009 | Microsoft Xbox 360 Console
Skipping 360
look on top of intake manifold..it gives firing order and distributor rotation..i believe it's 1 8 4 3 6 5 7 2 with a clockwise rotating distributor
May 02, 2009 | 1998 Dodge Durango
Xbox 360 dosent READ AND ROTATE WELL! PLZ HELP ME!
you will need to take this apart, and look inside the disc drive itself, and most likely tights some screws up as they get loose with the vibrations of the drive
Feb 16, 2009 | Microsoft Xbox 360 Console
Minka Aire F602-BNCH Gyro? Fan Logo
149 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
