Bettoni pencil refill - Office Equipment & Supplies
Where can I find refills
I get so annoyed when I cant find my favourite products or things are discontinued. But usually I call or email the manufacturer for starters. Not sure what country you are in however. They can usually send you a list of where to buy or will tell you if it is discontinued. Next try ebay make sure you look worldwide there is a little button on the left of screen. Revlon Eyebrow Pencil eBay Eyebrow Pencils Also last but not least a good old trusty google search. You will definitely be able to find it somewhere in the world.
Mar 16, 2014 | Revlon Fine Line Eyebrow Brow Refills...
How do you refill the Zebra M 301 mechanical pencil
pull the eraser out and put it in the end if that doesnt work pull the part holding the eraser and it should come out.
Jan 16, 2012 | Zebra M 301 Ultra Mechanical Pencil Black...
Please how do I refill my Bic Quantech #2 0.5 pencil? I have the correct size leads, but cannot figure out the mechanics. Thanking you, Margaret
Got it, thanks to the chap at OfficeWorks. Take the plastic cover off the eraser at the top of the pencil. Then wiggle the eraser out of its seat. Then you will find a hole going down the centre of the pencil, under where the eraser was. Drop a couple of leads into there, put the eraser back in, put the eraser cover on and Bob's your Uncle.
Cheers
Aug 29, 2011 | BIC Quantech Mechanical Pencil,...
How do you load a new lead?
To load more lead into the Zebra Z Grip mechanical pencil you must follow these steps:
1. Use the extra provided lead or purchase a refill package in 0.7mm size. 2. Remove the plastic cap that covers the eraser on the end of the pencil. 3. With the cap removed, gently tug the eraser out of the end. 4. When the eraser is removed, place a few pieces of lead into the open tube. 5. Insert the eraser. 6. Replace the cap on the end of the pencil. 7. Depress the end of the pencil a few times to feed the lead through the tip. 8. Write!
Mar 10, 2011 | Zebra Z Grip Mechanical Pencil, 0.7mm...
How do I refill the lead in a pentel twist erase pencil
Open the pencil in the middle, like pulling it into apart, then load the lead from there.
Sep 02, 2010 | Office Equipment & Supplies
How to place the lead refill in the pen
what kind of pencil is it? you can usually pull the eraser out and drop the lead in. but if worse comes to worse just hold down the button to release lead and put your refills through the business end.
Dec 24, 2009 | Colibri Watches
Refilled lexmark 23 cartridge but still shows
clean the terminals with damped cloth not wet
 try using a pencil eraser
Jun 11, 2009 | Lexmark X3550 All-In-One Printer
Hi i have a lexmark x5650 printer, i have just refilled the cartriges and it wont recognise them keeps telling me to replace them, any ideas any one ? neil.
I had same problem. I unplugged the unit, took a pink pencil lead and lightly cleaned the contacts, put the ink back in the plugged unit back in and it worked.
May 01, 2009 | Lexmark Office Equipment & Supplies
65 people viewed this question
jasbo
jasbo
