Question about Brother MFC-7340 All-In-One Laser Printer
Blank line copy page - Brother MFC-7340 All-In-One Laser Printer
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Check your toner and DPI + brightness in the printer settings
Other case is faulty driver
Posted on Jul 25, 2013
WHITE LINES ON FAXES SENT
You have white out or some other white substance blocking your scanner optics. I am assuming this is a thin blank line. What you need to do is make a copy of a document with your machine. You should see the very same blank line on your copy that your customer is seeing on their received fax. Now take this copy and place it in the document feeder the same way you placed the document when you made your copy. Now imagine this document going thru the feeder. The strip that is blank will "match up" with the white out or whatever is causing the blank line. You just need to open up the feeder section where the documents go in to be scanned and look for the thin strip of glass that runs from one side to the other. Using the copy you made with the blank line, use it to see exactly where the glass should have something stuck to it and clean it off with a soft clotch with a little glass cleaner on it. Go ahead and clean the while glass while you are in there. Once clean you can close it back up and run another copy to insure that all the lines are gone.
Good Luck and Thank You for using Fixya.
May 12, 2010 | Canon L220 Plain Paper Laser Fax
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
My copier is making copies that have a big blank area
Hi, first if you mean length of the page, remove the ink cartridge and see if a piece of paper is stuck on the roller where the power comes onto the paper, in line with that white line on the copy.
Aug 11, 2009 | Ricoh Office Equipment & Supplies
Top of page prints OK. Bottom blank
My first guess would be phone line problem. Print out an activity report (if you don't have a users manual you can download it at www.brother-usa.com ) and check to see if you have had any communication errors. If you notice no errors then make 50 test copies. If your test copies look good then I would lean towards a phone line problem. if they come out like you have described then I would start with your toner and drum first, second laser and third main board.
May 27, 2009 | Brother Office Equipment & Supplies
Error code F2-42
Are the lines horizontal or vertical? DO you get lines on B/W copies (black and white) also? If you try to copy a blank white page do you get the lines? Does the toner / lines wipe off after the copy comes out? If the toner wipes off after the copy comes out you have a problem in the fusing unit ( the hot area that fixes the image onto the page). If the lines are vertical then you have something inside the device that is dragging across the page as it goes through the device. If the lines are horizontal then you it could be the drum cleaning blade, the transport blade, or charge roller. The noise could be that one of the blades are bouncing. It could be that a gear is worn. Please give more info on the problem to better help.
Dec 31, 2008 | Sharp AR-BC260 Color Copier
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
Oct 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Why do I get a line of faint or no copying on the page?
Does this blank line run top-to-bottom or side-to-side, and which direction is the paper traveling through the machine, portrait or landscape?
Jun 03, 2007 | Minolta EP1031/1031F CS/PRO Copier
Brother MFC-7340 All-In-One Laser Printer Logo
12 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
