Question about Sharp CD-BA300 CD Shelf System
Bass dont work
I have been blowing alot of fuses and then one day i was playing music and it turned off and said protect. well i turned it back on and my bass is not woking and all my fuses are good. idk wha is wrong. I need help.
  • Sharp Master
  • 5,126 Answers
Fuses blow when there's an overload. These are often caused by the power transistors or in some models a Power IC, both of which can be found on the large heatsink. You will find that this time one of these has developed a fault that doesn't blow a fuse. You should be aware that the biggest cause of these problems is faulty wiring or a faulty speaker or in some cases the wrong type speakers being used. Incorrect ohms, say 4ohm speakers fitted when they should be 8ohms is another cause.
Posted on Jul 29, 2013
My amp plays two songs then goes into protection mode.
Most likely cause is one of your speakers has shorted out or the wiring to them. try disconnecting them one at a time as this may help isolate the problem.
Oct 15, 2016 | Car Audio & Video
Bm5a blows fuse when turned on
Blowing a fuse means that it has a dead short. The fuse does its job by protecting the other components while the circuit fails. Something is definitely burned out inside.
Mar 24, 2014 | Dynaudio BM5A Active Monitor
Amp has power ,is getting signal , meter moves when I hit the strings of the bass. but no sound coming out of either cab. ran a line out and it works that way ,
Looks like the power module went out, could be either LM3886T Power IC or Mosfet Module But certainly is in the output stage where your problem is, hope this helps to troubleshoot the issue at least...
Nov 03, 2013 | Behringer Bx4500h Ultrabass 450w Bass...
Can anyone help
What size is the amp and how many watts is the speaker(s) you have it ran too? If your speakers are trying to pull too much power from the amp it will turn itself into protect mode to keep from blowing a fuse as well as if you are pushing to many watts into small small speakers it will do the same to protect from blowing the speakers I would recommend turning the settings on the amp down slightly and then trying it out also make sure your wires arnt crossed adjusting the setting as it plays is the easiest way to fix the problem also make sure the bass isn't all the way up on your head unit
Jul 12, 2013 | Car Audio & Video
I lost some settings in the volume menu and sub volume
did you blow a fuse, or did you blow out your speakers.
Jan 30, 2013 | Alpine iDA-X100 Car CD/ MP3 Player
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Kenwood amp kac-x401m
How long will the bass play before the amp kicks into protection mode and how loud are you listening to it? I've noticed with my amps that if they don't have enough air flow they will get hot and kick into protection mode. They will also kick into protection mode if you are running it at more than it can handle. Check your adjustments on both your amp and the head unit. Make sure you are not running more bass than the amp can handle.
Nov 04, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Protector light keeps coming on
the reason why this is happining is that your pushing to much power than that amp can handle you need to get a bigger amp so it can withstand the power that you want to push to it also the red light comes on so you dont blow the amp.
Jan 08, 2008 | Sony XM-1252GTR Car Audio Amplifier
FWM587
Press the DBB button for Dynamic Bass Boost
Nov 11, 2007 | Philips FWC579 5-Disc CD Changer
Amplifier not working
Do yourself a favor and take it to a repair shop. It will be alot easier on yourself and you will get your amp back in working condition alot faster.
May 04, 2007 | AudioBahn A8000V 400W x 1 Car Amplifier...
Sharp CD-BA300 CD Shelf System Logo
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
