Question about Tally T2340/24 Matrix Printer
Tally t2340 eject error single
Hello, my tally t2340 is offline and when I try to turn it back online it display : Eject Error Single. How can i get rid of the error and turn it back on ? Thank you
2 Suggested Answers
  • 169 Answers
SOURCE: tally 2250 gives eject error single
The paper path on the 2250 has changed to the single sheet feeder, I guess you are using tractor fed paper loaded into the standard front tractors, if this is the case you can change the paper path to Tractor 1 in the following way;
1.Power the printer off and disconnect the printer from the computer system.
2.Press and hold down the SETUP button, and power the printer on. Keep the SETUP button held down whilst the printer initialises (this unlocks the printer menu)
3.When the printer has finished initialising release the SETUP button.
4.Make sure that the printer is in Offline mode; press the Online key, if necessary.
5.Remove any paper that may be loaded into the printer.
6.Press the SETUP button
7.Press the button under PAPERPATH (button 3)
8.Press the button under TRACTOR 1 to select the tractor feed
9.Press the ONLUE button to exit the menu.
Posted on Dec 14, 2011
How to fix up d5/5 and remove disc
I am not sure about the d5/5 error but you should be able to eject the disc by performing the following, which I took from my user manual.
Turn off the unit. Press and hold the [ >>/>>' ] and [ OPEN/CLOSE ] on the main unit at the same time for about 5 seconds.
Hope that helps.
Paul
May 14, 2014 | Panasonic SC-BT200 Home Theater Systems....
Tally 2250 gives eject error single
Dec 13, 2011 | Tally T2250 Matrix Printer
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
My Infinity 6 CD Player (2007 KIA Rondo) "displays Error 21" when you try to play, eject or change a CD. Does anyone know what this is?
Personally, if it were me, I would replace your indash changer with an aftermarket single disc player. Indash changers are notoriously unreliable and go bad very easily.
Jun 01, 2011 | Car Audio & Video
Eject Error message
I would suspect that the paper path has been changed via the control panel. If you are using continuous paper fed in from the tractor this should be Tractor 1 (unless you have optional tractors).
If the printer shows something like SINGLE on the display, it is for sure that the paper path has been changed.
Disconect the pritner from the computer system, and power the pritner off and ofter 10-15 seconds power the printerback on again.
  • If the menu shows as locked power the pritner on holding down SETUP to unlock the menu.
    Nov 18, 2009 | TallyGenicom T2265 Matrix Printer
    Printer screen message reads turn paper lever then online single Can't get it to print
    I guess you are using tractor fed paper, the type of paper with holes down the side.
    The problem you have is that the paper path has been changed on the printer to the single sheet feeder rather than the tractor feed, you will need to change this back again via the control panel, this is done something like this;
    1. Put the printer Offline
    2. Press Setup
    3. Press the button under PaperWay
    4. Change this to Tractor 1
    5. Press SET
    If the above steps do not work disconnect the printer from the computer then try again.
    For more info see the Dascom web site;
    http://www.dascomeurope.com/support2/technical_notes/serial_matrix/T2240/T2240_tn007.htm
    And look for the Online Single & Load section
    Oct 14, 2009 | Tally Serial Matrix T2130 Printer
    Tascam DA 40 DAT Machine ." Loading error "
    The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
    Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
    My tally 9 single user not opening my selected company
    i have problem regarding tally9 internal error
    software exception errorc0000005
    memory access violation
    sagar_manohar@yahoo.com
    Aug 25, 2008 | Computers & Internet
    Offline park eject error
    The problem comming from FAW sensor , adjust the FAW sensor. Check gears ,if it broken change it.
    Feb 14, 2007 | Tally T2245 Matrix Printer
    Tally T2340/24 Matrix Printer Logo
    87 people viewed this question
    Top Tally Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Tony
    Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
