The remote will only work about 2 feet from the receiver
    Top Expert:
  • 12,223 Answers
Open the keypads and cleant with contacts cleaner solvent, from dirty, oxide, corrosion, bad contacts. and try again. Clean the contacts batteries and replace by new ones.
test the LED when you hit any key LED must be turn ON. see the diagram attached, use digital camera
God bless youThe remote will only work about 2 feet from the re - 73c643d6-bf3d-4d27-9422-a5a829abdf69.jpg
Posted on Jul 25, 2013
Remote control won't work 10 feet away but if two feet away it works. What gives?
the remote uses light to send a signal to the tv. make sure there isn't anything interfering with the light signal. it could be dirty or the receiver could have dirt obstructing the light.
Mar 20, 2013 | Panasonic TC L42E50 - 42" VIERA E50 Series...
Remote will work from two feet away or closer. whats causing this
99% of the time the remote receiver is causing this problem--receives the remote infrared signal from you remote.
Nov 02, 2012 | Vizio Eco VO320E 32-inch Class Television...
Remote only works within a few feet
Either the lens on the front of the set for the remote receiver is dirty etc or the infrared receiver in the set is bad.
The having to get very close and the fact more than one remote reacts this way means the trouble is the receiver is bad.
I have seen this a few HUNDRED times in my career.
Jun 02, 2012 | Westinghouse SK-32H240S Television
Remote on off has very limited dstance
Possible bad IR receiver in TV or IR receiver is not located properly in TV.
Dec 30, 2011 | Vizio SV370XVT TV
I have a 2 year old Pioneer VSX-819H-K that only recognized the remote signal from about 2 feet away. Worked fine last night. Changed out the remote batteries three times, then programed a Cox...
hi,
You have to order for the IR receiver module for the system. Also check inside the frond panel of the system is there is any durst accumulated in frond of the IR receiver unit.
ok
May 07, 2011 | Pioneer VSX819HK 5 Channels Receiver
Trouble with remote on second TV, not responding from back of house
Hi, Mary with Dish Network Customer Service. The TV2 remote (UHF) can work up to 200 feet from the receiver but can also get interference issues that cause it to not work consistently. One of the things that I recommend is to readdress the remote to the receiver and possible installing a pigtail to the remote antenna on the back of the receiver. I have this on one of my receivers and have never had an issue since. To troubleshoot try these steps:
Step 1: Verify correct Remote being used
Check that the remote matches the TV. Use remote key or sticker on remote to confirm. TV1 is located in the same room as your DISH receiver.
Step 2: Check that UHF Remote Antenna is Secure/Upright
If UHF, check that your UHF remote antenna is securely connected to the "Remote Antenna" port on the back of your receiver and that the antenna is upright.
Step 3: Address Remote
To SAT: Access "System Info" - press and release the "SAT" button then press the RECORD button on remote control. If unable to access System Info using the receiver, use "Video Frozen/Locked Up".
To TV/DVD/AUX: Check for current remote codes and address remote.
Step 4: Check that Remote Control Batteries are Fresh
Check that the you have recently replaced the batteries. If not, install new batteries.
Step 5: Reset Receiver
If the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
Please note: It may take up to 5 minutes for the reset process to be completed.
If you are still having an issue, to install a pigtail you will need a piece of Coax cable, approx. 3 feet long and a barrel connector. Remove the remote antenna from the back of the receiver, attach the coax cable to the receiver. At the other end of the coax cable insert the barrel connector and add the remote antenna. Then drape the coax cable behind and towards where the TV2 is located. It takes the remote antenna away from where all the electronics are, which are major causes of UHF interference. I hope this helps resolve your issue.
Jan 14, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Remote control stopped working.
Hi forlillis,
1. Make sure there are fresh batteries in the remote, and they are installed correctly.
2. Make sure the area between the remote control and receiver is not blocked by some object,
and the distance is no more than 15 feet at an angle no greater than 30 degrees from the
front of the receiver.
3. Make sure strong lighting is not directed towards the IR sensor of the receiver.
4. Press each button on the remote and verify proper operation.
If these steps are taken and remote control still does not function properly
5. This step discharges the capacitor and resets the remote control. (You do not need to point
the remote control at the receiver or even have the receiver turned on.)
A: AVR35  Press the TV and the M4 buttons at the same time and hold for 12 seconds.
To Test: Make sure your AVR35 is ON, press each button on the remote and verify
proper operation of your receiver.
Let me know how it went.
lykohavi
Aug 05, 2010 | Harman Kardon AVR 35 Receiver
I have a 1/2 hp Sears Craftsman Garage Door opener about 18 months old when operating the remote within 5 feet or less of the opener the opener works properly. Upon exiting the Garage about 10-12 feet away...
The difficulty is determining if your remote or the receiver is bad. If you have another remote that works as it should then it is the remote. If you just have the one remote there is no way to tell which is bad.
Jul 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Onkyo tx-sv727 Protect displayed
first thing if it says protect, check the fuses inside the system they may of blown .When choosing wire gauge, consider the quality of your components and speakers, the overall sound quality you're trying to achieve, and the budget you're working with. Also, keep in mind the distance between your receiver or amp and your speakers long wire runs can cause significant power losses, and thus require thicker cable. You can use this as a guideline
Distance from speaker to amplifier Gauge
Less than 80 feet 16
80 to 200 feet 14
More than 200 feet 12
Nov 02, 2008 | Onkyo TX-SV727 Receiver
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
