Onkyo tx-sv727. Light comes on for standby and mr off but nothing shows on main display. The same thing happened to my old pioneer thats why i got this one but it is still happening. Thanks
SOURCE: Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Posted on May 12, 2008
  • 142 Answers
SOURCE: standby button stuck
Hello. Check all of the buttons on your unit to make sure that they are not stuck...you can feel the click they make as you push it then they pop back out as your finger pulls off. Any stuck button will lock up your microprocessor and keep the unit from turning on. All other problems will require a consumer electronics technician to trouble-shoot the turn on circuit. If you know how to use a meter and know how to solder\unsolder and require further assistance you can contact me. Good luck.
barneyluc
Posted on Oct 19, 2008
futureloginn
  • 734 Answers
SOURCE: I have an Onkyo TX-8511
as follows to our chat session, please rank me for the solution..
Posted on Nov 16, 2008
mjjdesigns
  • 98 Answers
SOURCE: Onkyo TX-SV 727 PROTECT mode
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
Posted on Mar 19, 2009
SOURCE: onkyo tx-sr500; power goes out; standby light blinks
Remove all Wires form speakers
Power on
Push Video1 + StandBy /On
appears Clear on display
Posted on Jan 26, 2010
Onkyo TX NR515 .. when in standby mode .. light is not coming on .. everything works fine .. i must have pressed something by mistake but cant work it out what ... on the display panel in standby mode...
If Zones are turned on or, if a mobile device connected to the Front Input is charging (MHL), the HYBRID STANDBY indicator won't light. See the TX NR515 owner's manual at http://filedepot.onkyousa.com/Files/own_manuals/TX-NR515_English.pdf for more info.
Feb 19, 2015 | Onkyo TX-NR515 AV Receiver
Onkyo tx-sr507. was listening to music and suddenly cut out. Will not restart despite disconnecting all speakers etc. standby light flashing
standby light flashing means that it has had a thermal meltdown given that the onkyo can not be that old i would contact onkyo support because our model should be under factory warranty
May 24, 2010 | Onkyo Tx-sr507 A/V Receiver
TX-V940 only comes on with standby/receive light on nothing on display
I HAD ONE AND IT DID THE SAME THING ONE OF THE BUTTONS WAS STUCK SO CHECK ALL THE BUTTONS AND IT SHOULD COME BACK ON IF THE STAND BY LIGHT IS ON
Nov 20, 2009 | Onkyo TX-V940 Receiver
Onkyo TX SV727 - Remote speakers won't come on
check the receiver setup menu, 'osd' button. youll find a menu item to activate the amp to output for zone2
Nov 02, 2009 | Onkyo TX-SV727 Receiver
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
Mar 19, 2009 | Audio Players & Recorders
Onkyo tx-sr500; power goes out; standby light blinks
Power on
Dec 22, 2008 | Onkyo TX-SR501 Receiver
Onkyo tx-sv727 Protect displayed
first thing if it says protect, check the fuses inside the system they may of blown .When choosing wire gauge, consider the quality of your components and speakers, the overall sound quality you're trying to achieve, and the budget you're working with. Also, keep in mind the distance between your receiver or amp and your speakers long wire runs can cause significant power losses, and thus require thicker cable. You can use this as a guideline
Distance from speaker to amplifier Gauge
Less than 80 feet 16
80 to 200 feet 14
More than 200 feet 12
Nov 02, 2008 | Onkyo TX-SV727 Receiver
Onkyo TX-SV727
did you press the enter button on the remote to display the menu? Make sure that monitor out is connected to the TV.
Sep 29, 2008 | Onkyo TX-SV727 Receiver
48 people viewed this question
 Grubhead
Grubhead
