Question about Caloric Dishwashers
Amalfi benchtop dishwasher E4 - Caloric Dishwashers
Dishwasher won't fill and e4 is flashing
Possible that the inlet valve or the filter is clogged
Click this link: Inlet valve
Jan 23, 2013 | Dishwashers
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
Hi, My Bosh lifetstyle dishwasher purchasedin Dec. 2010 is just about 10mm to high to insert under kitchen benchtop. Is there a way to remove the top of the dishwasher because then it would...
If it is a brand new dishwasher you should not be making any alterations to it otherwise it can affect the warranty.
Best to call the company representative and ask.
Dec 11, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
New world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Kenwood dishwasher kdw8st2a
I had E4. Initially couldn't get it to clear.
In desperation, switched it off, turned it on it side and drained it onto the floor.
The E4 disappeared and the dishwasher is working normally.
Jan 22, 2008 | Smeg 24 in. DWF614SS Stainless Steel...
Dishwasher time E4
e4 for most products means it must be reaplaced contacted the company they should be able provide a replacment
Oct 15, 2007 | Kenmore 46123 Stainless Steel Electric...
Dishwashers Logo
32 people viewed this question
Top Caloric Dishwashers Experts
Are you a Caloric Dishwasher Expert? Answer questions, earn points and help others
