Question about Garden
John deere 6414 assembly bolt torque
Rebuilding 6414T john deere engine and need the bolt torque and valve clearance please.
5 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: I have a John Deere LT 1`33 lawn tractor with a 13
I believe they are 8mmX35mm.
Posted on Nov 14, 2009
  • 3600 Answers
SOURCE: how to rebuild hydraulic pump on 4440 john deere
This is something that you need to have special tools to rebuild pump, your best bet is buy a rebuilt from a rebuilder manufacture.
Posted on Mar 26, 2010
wfservices
  • 262 Answers
SOURCE: i need to rebuild a hydraulic cylinder on a john
  1. This cylinder is not to hard to disassemble.
  2. Place upright in vise or suitable bracing.
  3. Using a block or dowel of wood(maybe rubber mallet also), depress the top cap of the cylinder to relieve tension on the ring.
  4. Use a small edged screw driver or pick and spin "retainer" in until the bent end comes to the opening.
  5. Lift up and rotate the ring more to allow the ring to pass over the edge of the opening.
  6. Once the retainer is started you can tap it with the wood and rubber mallet around the circumference of the cylinder to release the retainer from the groove.
  7. If you havent done so by now the oil should be drained.
  8. with the cylinder firm in vise(but not too firm to "distort the integrity of the cylinder.) Place the cylinder Sideways so you can pull out piston and rod assembly.*** Put hose or suitable drain on holes of cylinder***. With the motion of the piston the residual oil will tend to spray out.
  9. Pull on the piston and position it to bottom out on the top gland(cap) ie:full extension
  10. Place support under the rod to avoid damage. The gland is a tight tolerant fit with use of O-rings and backup rings. Too much offset can lead to damaging gland assembly, and jamming in the cylinder. You may be able to just hold with hand also depends on size, bore, stroke, pressure rating. Use due dilligence.
  11. Now that its out you have the piston assembly with gland in hand..**if only the rod comes out there are more steps to take, and you need a new rod but sometimes its more cost effective to buy a new cylinder. If there is a farm supplier or hydraulic dealer near they can certifiably /replace repair the cylinder for you. Hydraulic pressure is kind of like lightening. If it strikes you under pressure it can kill you.*** Using the dead blow or rubber mallet try to pop the gland out by using the piston/rod assembly as the puller. You may not have to remove the top clevice or other end of the cylinder, so maybe you could tap on that.
  12. The piston can be removed from the rod depending again on make. Usually a socket head cap screw or king nut holding it in place to the rod.
  13. When the piston is removed you should be able to slide gland off also.
  14. You'll need that pick and or the screwdriver to pick out the seals carefully. Let me know if you require more...WF Services
Posted on Apr 07, 2010
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
Have john deere d120 ride single cyl B&S 21hp they are prone to head gasket failure after 50 hrs.Would having the head retensioned reduce this happening would valve clearances need rechecking. Thanks
has the head gasket failed already or are you surmising that it will happen soon
having the head studs re-tensioned would help reduce the possibility of it happening as the studs are small in diameter and can stretch and loose tension
it would be advisable to check the valve clearance as B&S valves tend to stretch and that makes start when hot difficult
Dec 01, 2017 | John Deere Garden
Whats valve clearance for john deere D130 ride on mower, vee twin motor
Bring number 1 piston to top dead center, the valve clearance for both the intake and exhaust is 0.005" cold, once the valve clearance is set tighten the lock nut for the rocker arm to 70 inch pounds.
Jan 10, 2017 | John Deere Garden
How to replace pto clutch on John Deere x320
Removal and replacement fairly straight forward, you just need to prevent the engine crankshaft from turning. This can done either holding the flywheel or using a piston stop. Also some clutches have a set of flats that a 1-3/8 open end wrench will fit.
When reinstalling the center bolt torque to 50-55 ft-lbs. Also make sure the anti-rotation device is engage into clutch assembly or it will rip the wires out at the first startup.
Apr 07, 2015 | John Deere Garden
Engine torque settings and valve clearances
You need to provide engine model number such as KV3 or such.
Jan 03, 2014 | 2007 Hyundai Atos Prime
Toque specs on a 1971 in line 6 mercury comet's rod bearings and the clearance between the bearing and crankshaft
TORQUE SPEC FOR ROD BEARING BOLTS 19 - 24 FT LBS TORQUE SPEC FOR MAIN BEARING BOLTS 60 - 70 FT LBS, CRANKSHAFT PULLEY BOLT 85 - 100 FT LBS. MAIN BEARING OIL CLEARANCE .0005 - .0022 CONNECTING ROD OIL CLEARANCE .0008 - .0015 / SHAFT END PLAY .004 - .008 / AND ROD SIDE CLEARANCE IS .004 - .011 HOPE THIS HELP THIS INFORMATION I GAVE YOU IS INLINE 6 -200 AND INLINE 6 - 250 ENGINES
Nov 11, 2011 | Cars & Trucks
What is the valve clearance and head bolt torque on a nissan td27 engine 1996 model
valve clearance is .014 inch for intake and exhaust with engine warm.
head torque it 21 ftlbs, then 44 ftlbs, then loosen all, torque to 89 inchlbs, then to 21ftlbs, then mark and turn the bolts an additional 60 to 65 degrees.
cyl head sub bolts torque 80 to 100 inchlbs.
thanks.
Jan 13, 2011 | 1990 Nissan Hardbody King Cab
How do I adjust valve rods and what's the clearances ? Model325 John deere lawn tractor.
Hi I'm Dane, and I'm going to help you solve you problem. Glad to finally get this answered for you. The piston should be set to top dead center on the compression stroke. Adjust the valves when cold to .004 Intake and .006 Exhaust. Torque spec is 61" lb .If you found this reply helpful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Dec 06, 2010 | John Deere 22HP VTwin Hydrostatic 42"...
We were wondering the torque on the head bolts on a Kohler motor for a lawn mower.
Hi and welcome to FixYa. I am Kelly. These torques are from the Kohler Service manual for the
CV11-16,
CV460-465,
CV490-495
engine.
There are 5 bolts.... as you look at the bolts there should be 3 on the left side
Bolt 1 is the center (offset bolt)
Bolt 2 is upper right
Bolt 3 bottom left
Bolt 4 upper left
Bolt 5 lower right.
Torque them in the sequence above... to 15 Ft lbs. or 180 inch lbs
reset your torque wrench and then torque them to 30 Ft lbs or 360 inch lbs.
Rocker arms center nuts (called mounting screws) are first torqued to 55 inch lbs then to 100 inch lbs.
Then to set the valve lash you back off the set screw lock nut torque and set the valve lash to .003 - .005 final set screw lock nut torque is 65 inch lbs. Engine must be at TDC i.e piston all the way to the top to make the correct adjustments.
Thanks for using FixYa.
Kelly
Jul 17, 2010 | John Deere Garden
Specs for a 1997 Ford Ka 1297 cc
If the vehicle is fitted with a Rocam engine, the valve clearance is not adjustable, hydraulic lifters.
The camshaft caps are torqued in two stages, first 10Nm and than 90 degrees
Apr 10, 2009 | Ford Focus Cars & Trucks
Garden Logo
188 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
