Question about Sewing Machines
Upper thread is not catching bobbin thread
My bobbin thread is not catching. I've checked for broken threads in the bobbin case, cleaned bobbin case, rethreaded both upper thread and bobbin, and changed to a new needle. (And yes, the needle is installed properly with the flat side on the back.) As for the bobbin, it does seem to be catching under the spring but is not crossing over the bobbin case as it should. Any other suggestions?
  • 130 Answers
Carmen, seem that you have carried out the necessary rectification, but could it be your rotary hook tip blunt/broken, if not most probably it needs needle/hook timing adjustment. And this will require your sewing machine technician to do it.
Posted on Jul 25, 2013
Testimonial: "Thanks so much! I'm probably going to take the machine to the repair center today, as I have too many unfinished projects to complete."
  • Carmen Aug 02, 2013
    I took my Brother PE-100 to the repair center. I was told that the hook needs to be replaced but that part is no longer made. Does anyone know what this hook looks like and where I might be able to purchase one?........ebay, etc.......
SOURCE: bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Posted on Sep 06, 2008
SOURCE: bobbin thread not catching
Whenever you see loops on the underside of the fabric something is snagging the thread. the biggest culprit is burrs on the hook. the hook is what goes round and around the bobbin. The reason for burrs on the tip of the hook areseveral
ONE ...is by helping the fabric through as the machine is doing the sewing which directs the needle too close to the hook thus scarring the smooth surface of the hook and potentially breaking it off and the needle too. You must allow the machine do it on its own and only guide the material.
TWO...Sometimes if you are sewing s-t-r-e-t-c-h-y double knit material the material calls for a ball point needle. I have gotten good results with the Singer brand YELLOW BAND needle.
Three ... The hook could have gotten out of timing. What this means is that the hook is not meeting the needle on the top edge of the eye of the needle. You yourself can check this out by removing the bobbin (or shuttle, cassette). Install the needle flat side to flat side of the mounting rod and all the way up. By slowly turning the handwheel on the right slowly and watching that the eye of the needle is just below the hook on the upward swing of the needle and that they both meet dead center. This when you need to take it in to a repairman. FrankIy I don't like to advise this because of unscruppulous practices. My boss used to call me a virgin Mary because I wouldn't ripp-off the customers. Anyway at this time you can also check the condition of the hook carefully looking for nicks and scratches on or around the tip of the hook. If there is damage present you can file this down with a very fine emory board or by using a strip of 400 to 600 grit sandpaper as if your were buffing a shoe. If the hook is removeable by unsnapping the snaps on either side its easier to buff. Anything courser may contibute to the problem. If the paper won't remove the damage you may need a whole new hook. If its not removeable you will have to take it in to have it installed.They have to time it properly.
Four...The two disk that you mentioned also has a spring. That sping is there to pull up those loops. If the disks are full of lint from the thread going through. the clups of lint won't allow the discs to apply tension on the thread and thereby having tightened the tension so much that that spring is not working properly.You can clean the discs by raising the foot which opens the discs. With a long narrow pick pull out all that lint without scatching the discs. Check closely that the the thread goes across the top of the machine down through the discs pull up snug so the spring engages,through the take up arm,in the two thead guides, then into the needle front to back or right to left, if it is a side loading bobbin. Now the tension will work properly!
TESTING : Move the TENSION dial to mid point of the dial usually 5. This is your starting point.
With two layers of fabric ( not stretchy) and with a regular needle, set stitch length at about 12 per inch on the dial. Now sew about six inches. Raise the fabric and look at the results. Do minor adjustments necessary on your tension dial up 6...7.. if loose on the bottom 4...3..2 if loose on top.
If you did all the steps above those are the steps a repairman performs and charges $75 except me I used to charge $10 .
Brother machines are good quality it is those hidden gremlins that make a fun hobby frustrating when you don't have someone to turn to without having to shell out cash! Its been a pleasure!
jravenus
Posted on Nov 07, 2008
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
  • 15 Answers
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Posted on Sep 07, 2009
SOURCE: The bobbin thread is not
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Posted on Aug 02, 2010
Why can't thread tension be adjusted?
Upper thread breakage is usually caused by incorrect threading, the tension being too tight, or the thread is wrapped around the spool pin or catching somewhere in the thread path.
Remove the thread completely from the machine.
Install a brand new needle making sure it is compatible with the thread and fabric.
All About Needles
RAISE the presser foot and rethread the machine making sure it follows the correct thread path (consult the owner's manual). Verify that the bobbin is spinning the right direction in the bobbin case and the bobbin case is properly threaded.
Set the upper tension somewhere around the midway point between high & low numbers.
Retest.
If problems persist, there may be debris buildup stuck in the tension disk. Remove the thread. RAISE the presser foot, set the tension all the way to zero. Dampen a length of pearl cotton with rubbing alcohol and gently pull the pearl cotton DOWN through the tension disk a couple of times. Rethread with regular sewing thread, reset the tension to the midway point and retest.
If cleaning the tension disk does not help, then it is possible the tension disk is malfunctioning or broken. Take it for service.
Feb 22, 2016 | Sewing Machines
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
I have a Necchi 535FA sewing machine that will not catch either the thread, just leaves a stright line of thread not catched
also try rethreading the machine top and bobbin
if the suggestions don't help then it's possible that the machine
needs to be checked for a timing problem
Jan 15, 2013 | Sewing Machines
Bobbin case catching thread
I believe that you are talking about the assembly that holds the bobbin case in. The bracket that holds the bobbin case in must be adjusted to allow the upper thread to slide by. Check if the thread will go by this area without "hanging up" while rotating the hand wheel. Also check your bobbin to make sure you have the right one. If it is too high or wide it will definitely be a problem.
Apr 17, 2017 | Janome SEW MINI Mechanical Sewing Machine
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
Upper thread will not catch the bobbin thread
try a new needle
make sure the bobbin is inserted correctly
if these suggestions don't help & if the machine is still under warrenty take it back & let them check it
Mar 20, 2012 | Singer Sewing Machines
Upper thread keeps breaking on Brother ULT 2001
the tread gets stuck on in the thread take up arm, there is a joint ware the arm is rived to gather, the thread get caught between arm and the rived sheet steel . . take little silicon gasket and fill in the joint so thr thread can't get stuck where its rived
Jan 13, 2012 | Brother ULT2001
How to fix new home machine it model No.731016401. model 360 manufactured by Janome its not sewing cloths. The thread is placed properly but when i try sewing it starts to break the thread. it turns in...
Upper thread breaks
1.needle may be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
also check the thread take up lever to make sure the thread has not come off of it cause that can make the machine jam up also
Sep 20, 2011 | Sewing Machines
The thread keeps breaking. Could the AUTO tensioner be the problem ?
here are some suggestions, hope they help
Upper thread breaks
Lower thread breaks
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
Sep 18, 2011 | Baby Lock Ellure
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Sep 15, 2011 | Brother PE770 Computerized Sewing Machine
Sewing Machines Logo
382 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
