Question about RCA Universal Remote Control
Rcu704msp2n Quisiera el codigo par programar mi tv arca sony
    Top Expert:
  • RCA Master
  • 12,223 Answers
Vaya a www.remotecodelist.com + memorex.com
God bless you
Posted on Jul 25, 2013
VOTIT
  • 2071 Answers
SOURCE: no puedo programar el control
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
SOURCE: programar un vcr dvd
fck off this site is gay
Posted on Sep 29, 2008
  • 325 Answers
SOURCE: necesito los codigos para programar el control
Sharp 011,020,025,027,037,052,053,059
cheers
Little Dish Fitter
Posted on Oct 11, 2009
SOURCE: Requiero el codigo para programar un TV Home
En el buscador "Google" escribe ( J&M Electronics R-402 TV Codes) y de seguro encontraras el que necesitas.
Posted on Dec 01, 2010
gopakumarg43
  • 74383 Answers
SOURCE: codigo para vcr samsung
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Check associated ads too. Sometimes, it might help you.
Posted on May 31, 2012
Mi televisor es marca LG y quisiera poderlo apagar y prender con el control del dish network quisiera y me pudieran alludar?
Luis, mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Es un placer poder asistirle. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales sientase libre de contactarme directamente a: kimberly.escobar@dish.com
Kimberly.Escobar
Social Media Representative
DISH L.L.C
Aug 24, 2013 | Televison & Video
Necesito por favor el codigo de tv LG para programar mi control de DISH, perdi mi manual Gracias
Hola! Mi nombre es Kimberly y soy representante de DISH. Lamento la tardanza en responderle, ciertos codigos que pueden ser programados a su televisor LG son los siguientes:678, 520, 505, y 627. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si necesita ayuda adicional puede visitar este link aqui puede encontrar mas codigos y el proceso a programar el control http://www.mydish.com/support/program-to-tv-code-non-basic Tambien puede contactarme directamente a mi correo electronico.contactarme directamente a mi correo electronico.rreo electronico.
Kimberly.Escobar
Kimberly.escobar@dish.com
May 05, 2012 | DISH Network IR Remote Control
Codigo del control para ldtv sony bravia 32
Buenas tardes, Quisiera configurar el control remoto de mi DVD marca LG, con mi televisor smart Sony Bravia de 50 pulgadas, para poder utilizar las funciones de encendido apagado volumen y cambio de canales, se que es todo un reto por que mi DVD marca LG es viejo mientras que el TV Sony Bravia es Nuevo pero agradezco mucho su ayuda. Gracias
Aug 20, 2011 | DISH Network IR Remote Control
Como puedo programar una tv samsung con el control de dish
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
Kimberly Escobar
DISH Network
Aug 07, 2011 | DISH Network IR Remote Control
Nesesito el codigo de un tv jvc para programar
COMO BUSCO EL CODIGO DE MI CONTROL REMOTO DE MI PUR FLAT?
Apr 06, 2010 | RCA TruFlat 27F520T 27" TV
El codigo del control remoto de una tv mitsui
el control remoto del digitalizador motorola no trae codigo de acceso a la tv mitsui, cual sería el código de acceso; hablé a Megacable y no tienen registrada la marca de la tv así que no pudieron darme el codigo de acceso y me recomendaron que indaagara en internet
Dec 19, 2009 | Televison & Video
Televison & Video Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
