Question about Refrigerators
Holiday refrigerator parts
Thermostat for a model FRW 656
  • Roy Jahn Jul 26, 2013
    I have a free standing wine cooler (Holiday Refrigerator Co.)model number FRW656 serial number that I need a Thermostat for and I do not know the proper part number of this thermostat or who to order from.
  • Anonymous Aug 21, 2017
    (Holiday Refrigerator Co.)model number FRW656 I need a new motor for it.
I have a Maytag refrigerator. Before leaving for holidays four months ago I emptied it. When I came back from holidays I found ice in the freezer. I thought that the ice was harmful and i unplugged the...
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Heavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Just click below for more information;
There are 44 'Do-It-Yourselfer' stories about installing this part
Hope this may help you; Regards, VOTIT
Sep 08, 2008 | Maytag Refrigerators
I need a new glass top cover for a Holiday outdoor refrigerator
Hi,write down make and model then google company it was made bye,hope this was some help all the best,hope you find the part.
Nov 12, 2015 | Refrigerators
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
I operated the "Holiday Mode" button on my Model WSE6100WA fridge. After returning the temperature display etc does not illuminate so I can't operate any temperature controls
The eco/vacation mode only exits when the door is opened if it was started automatically by the refrigerator. Since you pressed the eco button, you'd have to press the eco/holiday button until the display shows no icon for the feature.
How long did you have the power off to the refrigerator? Try pulling the plug for a 5 minute power outage. If that doesn't solve the problem, I suspect your appliance may have been damaged by a power fluctuation while you were away. Without additional information, I can't tell if only the display panel is damaged or if something else is wrong. The parts diagrams for the refrigerator are available here: http://spares.bigwarehouse.com.au/index.php?cPath=64685_78487_78846 .
I hope this helps.
Mar 10, 2014 | Refrigerators
Fridge freezer not working
If its a whirlpool side by side ou a kenmore then good chance it a thermostat. Turn it off and back on, if nothing happens check timer.
Aug 19, 2012 | Refrigerators
Everything inside is frozen no matter what it is set at
The thermostat is very likely the cause in this case. Finding a model number like this example=> 362.154879 on the Compact Refrigerator will help you find the part number. Or unplug the refrigerator and disconnect the two wires on thermostat along with the mounting screws and then take the thermostat to a local refrigeration parts supplier. They can test and help you find a matching replacement thermostat, Hope this helps, Thanks Sea Breeze
Sep 25, 2011 | Kenmore 91365 Compact Refrigerator
I have a GE refrigerator model # GSL25JFPABS. I have been told that the main control board WR55X10656 has been "replaced" by # WR55X10942 now. However I found a 656 board pretty cheap locally and...
WR55X10942 is the board that goes into that machine,it's the most up to date board out there,why would you put a first generation board in there that you know is gonna fail when they upgraded it to the WR55X10942 and that's the board it calls for now so don't put the other board in there
Apr 19, 2011 | GE Refrigerators
Magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
Jul 29, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
