Question about Garden
John Deere 6414 engine assembly torque specs
Need all bolt torques and valve clerance for a John Deere 6414 engine.
  • 25 Answers
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Posted on Mar 17, 2009
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
  • 701 Answers
SOURCE: torque specs for toyota tercel
Hello vienotkelly: The correct Main bolt torque is 42 foot pounds. The connecting rods torque to 29 foot pounds. The torque sequence for the head bolts and the correct way to tighten the bolts are attached to this reply. Thak You for using6bd0ae1.jpg FixYa. Roger
Posted on Apr 15, 2009
  • 376 Answers
SOURCE: what are the torque requirements for the valve
25 in. pounds
Posted on Jun 18, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
WWhat is the torque spec for the bolt that holds the pulley to the motor
Try looking up the size bolt on this chart.
http://www.imperialsupplies.com/pdf/A_FastenerTorqueCharts.pdf
Oct 29, 2014 | John Deere 2012 Gator XUV 4x4 550
What torque do I use when replacing the cylinder head on a John Deere 110, Briggs and Stratten 19.5 hp
Stuart,
Do an internet search for torque specs 2011 John Deere D110. You should be able to find the service manual for this product easily.
Sep 29, 2014 | John Deere D110 42 in. 19.5 HP...
Oil around the spark plugs
Check to make sure the plugs are tight and torqued to manufacturer's specs. Also, your Valve cover gasket(s) may need replaced.
May 21, 2012 | 1990 Honda Accord
Torque spec for pushrods on a 3.1 v6 engine
Its not a torque spec the engine has hydrolic lifters and needs to be adjusted with a feeler gauge . Its called a valve lash adjustment its around 14 to 16 thousands of an inch the intake valve is the lower one because the exhuast gets hotter and expands more and also needs to be done in a speiscif sequence but after you line it up you just turn the engine manualy and you do them right down the line ,You should call a chevy dealer to make sure of the exact clerances and order for your vehicle but if done right it will run real quit and likely much better
Jun 04, 2011 | Isuzu Rodeo Cars & Trucks
We were wondering the torque on the head bolts on a Kohler motor for a lawn mower.
Hi and welcome to FixYa. I am Kelly. These torques are from the Kohler Service manual for the
CV11-16,
CV460-465,
CV490-495
engine.
There are 5 bolts.... as you look at the bolts there should be 3 on the left side
Bolt 1 is the center (offset bolt)
Bolt 2 is upper right
Bolt 3 bottom left
Bolt 4 upper left
Bolt 5 lower right.
Torque them in the sequence above... to 15 Ft lbs. or 180 inch lbs
reset your torque wrench and then torque them to 30 Ft lbs or 360 inch lbs.
Rocker arms center nuts (called mounting screws) are first torqued to 55 inch lbs then to 100 inch lbs.
Then to set the valve lash you back off the set screw lock nut torque and set the valve lash to .003 - .005 final set screw lock nut torque is 65 inch lbs. Engine must be at TDC i.e piston all the way to the top to make the correct adjustments.
Thanks for using FixYa.
Kelly
Jul 17, 2010 | John Deere Garden
Torque spec on a 425 john deere head
Initial torque-115 inch pounds,final torque-186 inch pounds.Intake manifold is 53 inch pounds on all 8 screws.Valves set at 0.010 on all 4.If you go with the new style valve cover gasket {the flat one} be sure to leave the old o-ring in valve cover to keep the new gasket from splitting.
Feb 09, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Specs for a 1997 Ford Ka 1297 cc
If the vehicle is fitted with a Rocam engine, the valve clearance is not adjustable, hydraulic lifters.
The camshaft caps are torqued in two stages, first 10Nm and than 90 degrees
Apr 10, 2009 | Ford Focus Cars & Trucks
Garden Logo
263 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
