Question about Gear One Used Pa2400 8 Ch Powered Mixer 2 X 400 Wt Regular 886830617393
Gear one pa2400 8 channel mixer
Where do i get a owner's manual for this?
  • Gear One Master
  • 3,368 Answers
This is all I could find, I hope it helps. https://www.google.com/?gws_rd=ssl#q=gear+one+pa2400+user+manual
Posted on Oct 23, 2014
How to add oil to cuisinart SM-55 stand mixer
The owners manual is available on the website. It doesn't mention anything about adding oil. What makes you think it needs oil. Mixer gears are usually lubricated with white grease and are maintenance free.
Nov 23, 2013 | Food Mixers
The mixer won't work the pasta attachment, keeps rotating the mixer motor.
It sounds like it could be a possible stripped gear. You could have a bad attachment drive gear or bevel pinon gear.
Best thing to do would be to take the mixer apart, and inspect those gears. Here is a link to the service manual which will aid you in taking apart your 4.5 quart mixer: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Here is a link to the attachment drive gear: http://www.mendingshed.com/attachmentgear.html
Here is a link to the bevel pinion center gear: http://www.mendingshed.com/pinionwormgear.html
Let me know if you have any questions.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 27, 2013 | KitchenAid K45SS Classic Stand Mixer
Owners manual for Behringer xenyx 1204 USB
Behringer has the documentation for the Xenyx X1204 USB Mixer on the product page: http://www.behringer.com/EN/Products/X1204USB.aspx . See the drop-down menu labeled Documentation on the left side of the page; it's below the list of stores that sell the unit. The owner's manual is at the bottom of the list in that menu.
The file is a PDF so you will need Adobe Reader or a similar program to display the 3.1 MB file.
I hope this helps.
Oct 24, 2012 | Behringer XENYX X1204USB/1204 USB...
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    My stand mixer's motor runs but the blades don't turn to mix the food
    Get a copy of the Repair Part List for your model at Kitchenaid.com
    Download a Copy of the Kitchenaid Service manual.
    http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
    The Worm Gear (12) teeth was stripped and needs to be replaced.
    The whole Worm Gear Assembly can be purchased on eBay for under
    $15.00
    Aug 04, 2011 | KitchenAid K45SS Classic Stand Mixer
    I need an owner manualfor a Behringer pmp 3000 16 channel mixer
    You can download the manual by clicking this link
    You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
    http://get.adobe.com/reader/
    Hope this solves your problem. Thanks for using FixYa
    Jan 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
    Channel mixer problem- No channel B output.
    Probably time for an upgrade to a newer channel mixer. Your mixer is probably not worth fixing, but you could continue to use the mixer side for a while until you decide to upgrade that. If you happen to know an electronics tech, it could be a little project to check the power amp insert jack on channel B, but it wouldn't be worth spending good money after bad when you could put it towards more solid gear.
    Good luck.
    The dude.
    Aug 07, 2008 | Peavey 32fx USB 32 Channel Mixer
    Gear One Used Pa2400 8 Ch Powered Mixer 2 X 400 Wt Regular 886830617393 Logo
    506 people viewed this question
    Top Gear One Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Gear One Audio Player and Recorder Expert? Answer questions, earn points and help others
