Question about RCA F38310 38" TV
TV/Remote Issues This is a weird situation. The only way I can turn the tv on is by touching the power button on the tv and clicking power on the rca universal remote. This also happens when I want to change the volume, change channels and change inputs. Never seen this before.
    Sergeant:
  • 279 Answers
Odd problem alright. So you have to hold in the power button for the remote to work, and the power button won't turn the TV on by itself? Or am I misunderstanding. It sounds like the power switch relay is bad... and the board the receives messages from the remote is perhaps on the same circuit. The switch will need to be replaced. I wasn't able to locate parts online for this. RCA has a link to parts, but all they have is a replacement lamp. However, there is a service center locater link on RCA's page. http://direct.where2getit.com/cwc/apps/w2gi.php?client=rcathomson&template=searchretail_new Most places should be willing to sell you the parts you need, or get you in contact with those who do sell them. Or, you could just take it to them to be fixed.
Posted on Aug 30, 2007
How to shut off manually
UN55D6400UF TV Will Not Power Off If your TV is on but will not power off when you press the power button, you could be having an issue with your remote control or a faulty circuit inside your TV.
To determine the source of your problem, follow these steps:
  1. Power the TV on if it is off.
  2. Unplug the TV from the wall outlet for 30 seconds, and then plug the TV back in.
  3. namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=yokn68wxkhym@namo.co.kr&sep=%7c
    1. Press the POWER button on the remote control.
    2. [img src="http://support-us.samsung.com/cyber/namo/namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=79HKC8BOY9YC@namo.co.kr&sep=%7C" height="51" border="0" width="50">
      • If the TV powers off when you press the POWER button on the remote control turn the TV back on continue to Step 4.
      • If the TV does not powers off then there is a problem with the remote control. Click here to go to the Remote Control troubleshooting section of this guide.
    1. Press the POWER button on the TV.
      • If the TV powers off with the remote but does not power off with the power button on the TV there could be an issue with the touch sensor on the TV. Before setting your unit up for service try these two things.
        1. Try sliding your finger accross the power button.
        2. Have other people try using the touch buttons on the TV.
        3. If either of these two options work then there is not an issue with the touch sensor on the TV. There are many variable that can limit the conductivity of a persons fingers. The conductivity of your fingers might not be enough to easily control the touch sensor on the TV.
        4. If the TV does not power off when you press either the POWER button on the TV or on the remote control, then the TV will need to be serviced. Click the Create online service request button below to have the TV repaired.
Mar 26, 2014 | Samsung UN55D6400 - 55" 1080p 3D LED LCD...
Rca 42pa30rq
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Mar 18, 2014 | Televison & Video
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Hello I have a universal remote control for tv sanyo but I lossing de manual instruction and Iand ree program my tv. only I need how cam progarm my remote control pleaswed thanks.
Here is the steps on how you can reprogram your RCA tv remote control:
1. Turn the television on by pressing the "Power" or "On" button that is located on the set.
2. Press and hold down the "Code Search" button located on the RCA TV remote. 3. Press the "TV" button on the RCA TV remote. Once you press this button, you can release the "Code Search" button
4. Start pressing the "On/Off" or "Power" button that is located on the RCA TV remote. Keep pressing the button until the television shuts off. 5. Press "Enter" on the RCA TV remote to save the code on the remote. The remote will then control the television.
Apr 07, 2011 | RCA Universal Remote Control
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
RCA model# F26071ES television set clicks on, then immediately off when using power button on TV or by using remote.
This should help you.. use the TV button on the remote instead of the power button. If the TV is working properly and the buttons aren't damaged this should do it.
I know mine clicks off as well.. unless I use the TV button to turn it on.
Chey60
Nov 01, 2008 | Televison & Video
Freak accident, won't show 75% of channels now!
I lost the manual to this set, but last night I found the Menu button on the remote. I pressed it and then clicked SetUp. There was an option for Quick SetUp of Cable/Satellite. I clicked that and it was then able to find all my cable channels again. I still do not know how we messed it up by bumping the remote -- especially when it was turned 90 degrees away from the screen -- but this has restored it. Thanks.
Jun 22, 2008 | Sharp 27K-S100 TV
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Tv acting wierd
Must be leaky processor
Oct 15, 2007 | RCA 20F530T 20" TV
Using an RCA universal remote
WIKIPEDIA has this link for your situation: How to Program an RCA Universal Remote Without a "Code Search" Button http://www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button I think that should help with your situation. Let me know if it does not.
Aug 23, 2007 | Sansui COM3101 13" TV/VCR
RCA F38310 38" TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
