Question about Refrigerators
Maytag mcd2257kes - insufficient voltage to operate evaporator fan
I have an mcd2257kes and it worked fine. The local power utility had an issue at our transformer that fried some of my arc-fault breakers and also stopped the fridge from cooling. Erratic behavior - freeze, then thaw, etc. Saw that the main control board had a couple of blackened (fried) parts on it. Replaced it with a new one and assumed life would be good. Not so. Took the freezer rear metal wall out to see that the evaporator fan was not firing up, even though the compressor did and the coils were appropriately frosted. So i ordered a new evap fan. No dice. The fan runs on 110v but the two red wires that it plugs into are showing a varying voltage between them (8.7v to 16v). Very odd to me. Traced the power from the cord up through the chassis and I do have 110v at the control board. My refrigerator says it should be programmed to Code 20 (which I did). I am baffled by this but assume it is something simple I may be overlooking. Appreciate any help you have to offer.
  • 2 more comments
  • banderson045
    banderson045 Jul 26, 2013
    the evaporator fan in the back of the freezer compartment.
  • Day Coker Jul 26, 2013
    Check your defrost control it maybe getting stuck in defrost mode. Also check voltage to the fan with door switch closed or tape it down see what you get.
  • banderson045
    banderson045 Jul 30, 2013
    Votage today is 24-26v whether the door switches are open or closed. Jazz board was suggested (even though new) by an appliance repairman I hired. Hard to believe but am trying to get it swapped again (10 days past standard warranty). Open to other actions or suggestions. Brett
  • banderson045
    banderson045 Aug 15, 2013
    This is now resolved. The issue was the main control board. The part I bought from ApplianceParts365 was defective. They were very good about swapping for another though - even though I was 10 days past warranty. I am grateful for all assistance from them and this forum.
    Sergeant:
  • 304 Answers
Confused the condenser fan is in the back by the compressor and the evap fan is inside of the freezer which one did you change?
Posted on Jul 26, 2013
Testimonial: "the evaporator fan in the freezer compartment is what I swapped out."
  • Day Coker Jul 30, 2013
    Is your refrigerator making any intermittent buzzing or clicking sounds? Have you ohmed out your compressor?
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Sea Breeze
  • 4654 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
Sea Breeze
  • 4654 Answers
SOURCE: Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Posted on Aug 25, 2009
Testimonial: "You were right, thanks for your help. The control board was bad. That is what I suspected, but I wanted a second opinion."
heatman101
  • 43501 Answers
SOURCE: Amana AFF2534FES freezer has frost on back wall,
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 27, 2010
Maytag mgr5750 convection fan not working
check fan connection for voltage during operation requested. if no voltage then it is the control. if there is voltage then it is the fan itself. hope that helped and thank you for reading this.
Oct 10, 2014 | Maytag MGR5875QDS Stainless Steel Dual...
Power Automatic low then balnce
Do you have other loads pulling the voltage down, compressors in airconditioning, motors, etc. Perhaps when you measure voltage at 230V which should not cause a issue it's within 10%. But maybe a motor pulls in and drops it further than you measured? Re-check with meter and record. Check generator for overloading and also wiring size feeding
Aug 28, 2013 | Honda Electrical Supplies
My maytag evaporator fan not working
Need to verify that there is power going to the fan. If no power at the fan verify the door switch is good. If door switch is good and in the closed position you still do not have power at the fan you have a bad board. If you do have power at the fan but the fan is not working with the door switch in the closed position you need to replace your fan.
Aug 31, 2011 | Maytag MFD2560HES Bottom Freezer French...
Compressor in fridge not working. Freezer is working fine. Is there a reset button? What steps can I take to see if this is a simple issue?
There is one compressor that serves both the freezer and refridgerator compartments. You need to confirm if the evaporator fan in the freezer compartment is working. When you open the door to the freezer, you should see and hear the evaporator fan in the freezer compartment running. Particularly if there is a demand on the unit through the thermostat setting. If the evaporator fan is not operating, you can check the evaporator fan motor with a volt meter to see if it's getting power. If its getting voltage, but not operating, you need to replace the evaporator fan motor in the freezer compartment. There are 3 wires that attach to the evaporator fan motor. One hot wire, one neutral wire and one ground wire. The ground wire is usually marked green, the voltage wire is usually marked black and the common wire is usually marked white. You should get a reading on your volt meter of a voltage from the hot post to the neutral or from the hot to the ground. If it is getting power but will not operate, then it is definitely a bad fan motor that would need to be replaced.
Oct 04, 2009 | Refrigerators
Freezer not freezing fridge not cold, freezer frosted up
Oct 03, 2009 | Refrigerators
FREEZER WORKS, REFRIGERATOR DOES'T
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Maytag MFD2561HES Reefer not cooling
hello frooska,
kindly look at the back panel of the freezer section. if you can hear the humming sound, find out where it is coming from. if the sound is coming from the compressor, that means the evaporator fan is not running.
but, take note that u need to press the door switch of the freezer in order to check the fan. the fan stops every time the door is open. if the fan is not running, you have to remove the middle panel, above the evaporator, the fan would be there. ( in the freezer section)
but if the fan is running and the back panel of the freezer is full of frost, then that would be a defrost issue.
defrost heater, bi-metal or defrost controller.
Tnx 4 uisng Fixya,
Drcool
Dec 16, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Fridge Maytag model MCD2257KES. The fridge is getting power because the light comes on when the door is open. It for some reason lost all its cooling. Is there a rest button?
Under the front kick plat on the bottom there is a device called a defrost timer.. these go out quite a bit.. also the coil cooling fan could have gone out which is allowing the conpressor to overheat and making the compressor shut down and not allowing it to cycle enough to keep it getting cold... check these things out..
May 30, 2008 | Maytag Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
