Question about Kitchen Ranges
Whirlpool speedheat 2600
Large burner overheats on medium setting
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
Posted on Mar 18, 2009
richroth
  • 9472 Answers
SOURCE: stove overheats and sparks
All parts come with a 365 day, any part, any reason return policy.
Posted on Mar 12, 2013
Stove overheats and sparks
Mar 11, 2013 | Kitchen Ranges
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
GENE
Sep 23, 2011 | GE Cooktops
How many BTU's are in each element of a 1990 model hardwick propane stove?
Hello, it will depend on the size of the burner. If you have two large burners, one medium, and one small burner. It will also depend if you are using NG. Now, with LPG, it would be about 10 % less than natural gas. I am take a guess here, OK. Large burners 5000 BTU's. Medium: 2500 BTU's, and the small maybe 1200 BTU's per hour. Now, most of the burner on newer stove/ranges are set by the industrial standards. GB...stewbison
Sep 04, 2011 | Kitchen Ranges
Model 3186173 cooktop bottom left large overheats on lower heat settings
First thought must be a bad burner switch invalid model number, the number you gave is the panel part number
Mar 23, 2011 | Whirlpool Kitchen Ranges
My problem is the large burner on this stove tends to do somewhat ok on anything below a medium temperature. If you turn the burner to medium it escalates to high and refuses to lower even when you put the...
Replace the switch that controls this burner to get it back under control. This will solve your problem as the switch is what controls the burner temperature regulation.
Good luck!!
Jun 15, 2010 | GE JBS03 Electric Kitchen Range
Burner works on high (9), loses heat at medium (5)
The control is bad. I assume the burner worked on the other side?
eric
Jul 03, 2009 | Kitchen Ranges
Our Whirlpool speedheat 2600 burners shut down whenever we try to boil water when canning or even making pasta, what do we do?
If the pot is too large or to small for the burner or is concave or convex, the burner will short cycle. Try to match the burner to the pot and be sure the pot is nice and flat on the bottom.
Apr 08, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Mar 18, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Have a whirlpool electric glass top stove
You must replace the burner switch for that burner.
Mar 08, 2009 | Whirlpool RF379 Electric Kitchen Range
Burners overheat
The burner control is failing for each burner. That model takes part #316021500 for the 6" units and part #5303935086 for the 8" unit.
This must be an older range, as Frigidaire lists the 6" switch and no longer in production. You can replace a 6" control with an 8" but not the other way around...
Hope this helps. Please rate my answer if this is the case.
Dec 12, 2008 | Frigidaire FEF316 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
