Question about Air Tools & Compressors
How to adjust 350edelbrock carberator ? - Air Tools & Compressors
    Master:
  • 443 Answers
If your talking carb on a car or truck engine , 2 1/4 turns out both air fuel adj. and then adjust in 1/4 turn increments until your not lean or back if its too rich . But when you first start right down how many turns to bottom those a/fuel screws out font crank them down you will damage them
Posted on Sep 06, 2013
Please assist me in adjusting my carberator on a arctic cat 400 atv
Bring extra main jets with you. Keep an eye on your spark plug. if it starts looking like its burning whiter you need to bump up your main jet size!
Aug 31, 2014 | ATVs
How to adjust a carberator on a 1979 datsun 310
Screw mixture inwards until the motor starts to cut out then back outwards until it smooths . Screw has a spring on the thread.
Jul 26, 2014 | Vehicle Parts & Accessories
Carberator adjusting
Many new units have a very limited adjustment possibility. This is due to EPA regulations. If the saw is hard to start, it may need to be richened up a little. Your dealer should have proper tool to adjust.
Apr 14, 2014 | Husqvarna 36 41 50 51 55 136 141 154 254...
Sucking air in carberator
perhaps a carberator adjustment then, would say it's running kinda lean maybe
Mar 10, 2013 | Garden
How to adjust carberator
Some Husqvarna carbs require a special screwdriver to adjust them, some just use a mall flat head tuning screwriver.
Screw both H and L screws in. Then turn them out anticlockwise the following amounts to return them to standard.
H 3/4of a turn L1 full turn (Chainsaws)
Some equipment like blowers and strimmers are:-
H 2 1/4 turns out L 2 1/4 turns out
Nov 03, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
New carberater and a mechanic needed!
Even if you do it yourself you need to adjust it.I would get another mechanic to look at it also.Have you tried cleaners? 1 type you add to the gas the other you remove the air bonet and spray into the top of carb while running (have someone press on the gas lightly so you don't stall.Have you tried to increase the idle via the adjusting screw? has the auto choke been tested..adjusted? Good Luck.
Sep 17, 2009 | 1984 Honda Prelude
Engine cant run with air filter fitted, I have cleaned it .but the problem remains the same
This means that you are over fueling. There is more fuel going to the carberator than air. By removing the air filter you are allowing more air flow into the carberator, which is allowing the engine to run right. Natural gas and propane generator must have no more than 11 inches of water column. Gasoline engines should have no more than 3.5 psi out of the electric pump. If gasoline is gravity fed, then this means that you need to rebuild the carberator or purchase a new carberator, but try to adjust the flow valve on the bowl of carberator first.
May 19, 2009 | Kipor Parallel Wiring Kit, 30 amp...
Need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Jul 11, 2008 | Electrical Supplies
Air Tools & Compressors Logo
129 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
